How much weight on B3030 tow bar?
   / How much weight on B3030 tow bar? #1
Flyfish Nerd
Koppang, Norway
Kubota B3030 HST
Hello!
I am thinking about towing my 3.5 meter trailer to transport a load of fire wood.
I can mount a ball on the standard tow bar I have found under the PTO, but how much weight can I pull with this tow bar?
Kind regards,
Edward
   / How much weight on B3030 tow bar? #2
I couldn't find any towing specs on your B3030 but it is similar in size to one of my previous tractors. I had a Mahindra 2615HST with loader, 26 HP. Weight with loader was about 3500-3600 lb. I used mine to move a 30' camping trailer weighing about 6000 Lb. but only did so on level ground. I would have never tried to go up or down hill for lack of stopping ability. Also used to move other trailers around as needed in the 2500 lb range. Your tractor with loader a weighs similar 3000-3500 lb. I think you'd have no problem towing a 3.5 meter trailer with a load of wood weighing about 3000 lb. on level ground. Up or down hill would be tough to stop or have enough traction. If used on level ground I have towed about twice the tractors weight without worry.
Hopefully a 3030 owner will reply with some more accurate numbers.
   / How much weight on B3030 tow bar? #3
In my opinion, if you're towing on the level, you can pull a ton or a click over with no problem. I believe the manual recommends 1,500 lbs. Here is a shot of my B3030 towing a lift around the property that weighs in close to a ton.
   / How much weight on B3030 tow bar? #4
My B3200, which is the same tractor with a few less features, is rated to tow 3300lbs (1495kg) and handle 800lbs (362kg) of tongue weight. I'm sure yours is similar. That said, if it is tough going, i.e. steep, soft, slick, etc sometimes it may only tow half that much.
Thank you all for the information! I will give it a try.
Kind regards,
Edward
   / How much weight on B3030 tow bar? #6
I should of took this shot earlier. When all else fails, go to your bible--the owner's manual.
   / How much weight on B3030 tow bar? #7
Small world, I have that same lift, except I have the dual power model that also has a gas engine on it. I love it. Have you found any kind of forum for folks who own these things?
   / How much weight on B3030 tow bar? #8
I don't know of any chat rooms for these lifts. The lift in the pic was rented by me to clean my chimney. I have a very difficult chimney and prefer to clean my flue pipe from the top down, keeping the wood insert door locked and all the cresote inside. Here's a shot of me on another lift, cleaning the chimney.
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
1273 (A50490)
1273 (A50490)
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2017 Chevrolet...
2017 Nissan Altima Sedan (A48082)
2017 Nissan Altima...
2016 Ford Escape AWD SUV (A48082)
2016 Ford Escape...
