ls 4047 grapple
/ ls 4047 grapple #21
I just ran my hoses this past weekend. I used 1/2" 2 wire 3000 PSI hose. Here is a list of parts available at your local TSC store.
You will have to measure for the length hose you will need. I don't have any front hydraulic attachments yet just wanted to have the lines run for when I do. You can use 1/2" or 3/8" line but you have to bush the 3/8" hose up to 1/2" male pipe to fit the couplers.
My list
2- SKU# 1819884 - 168" (14') long 1/2" 2 wire 3000 PSI hose w/ male to male pipe each end
1 - 5006-4 - Double breakaway clamp with bracket to hold the front couplers
4 - SKU#1818626 - 1/2" male to 1/2" female swivel (or 1818105 1/2" male to 1/2" female 90's, your choice)
6 - SKU# 1824407 - VP4200-4 (or VP4000-4 your choice) 1/2" pioneer 3000 PSI coupler sets. (I bought some extra)
I also bought a 4' jumper hose I used to bleed the the lines. I can later use the 4' hose to connect to a front cylinder when I get something to install that needs hydraulics. I still have to get the rubber caps to plug in the couplers when not in use. They were out of stock.
I ran the lines under the tractor in between other lines and up to the front. I just used zip ties about every foot or so front to back. If your tractor is HST make sure you don't run the lines under where the pedals arms. I ran mine between the fwd and rev arms.
Nice job George! Now I'm waiting for you to buy that "Thumb" and mount it on your pallet forks & bucket so I can see how to do it. He.....He! ;) :thumbsup:
/ ls 4047 grapple #22
Just have to save up again to order the thumb. I'll probably have to call them since I haven't seen the one I want advertised in over 3 weeks. It'll take time but I'll get it.
/ ls 4047 grapple #24
I have my eye on that too, looks like a well-built & reasonably priced unit and very adaptable for many uses.
I would like to know what the travel is on the 36" is. I would like to mount the 36" on my 48" forks.
/ ls 4047 grapple #25
I'd like to know the travel also. It will be pretty much the same on any of his thumbs since they all use the same cylinder. Only problem I see is the cyl. only has a 6" stroke. I haven't found a video of one installed on anything yet. I'm sure it will close down on the bucket but unsure how far between the forks it will go with only a 6" stroke. I'd hate to buy one only to have to replace the cyl. with a longer stroke one and maybe relocate the mounting hole locations.
/ ls 4047 grapple #26
I suppose if it didn't close down far enough I could weld some extension "teeth" on the end of it. When it is retracted I want it mounted vertical so it is out of the way for picking up pallets.
/ ls 4047 grapple #27
Here's another one I found that looks well built. It's about $675. incl shipping. It also uses a 6" stroke cyl. but a larger dia piston and the tines are 1/2" thick.
/ ls 4047 grapple #28
That one looks almost too heavy for what I need, I don't know, maybe not! :) :confused3:
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A61574)
2018 Freightliner...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
2024 14ft Pairboat Flat Bottom Mud Boat w/ Mudd Buddy HDR 5000EFI 40HP Mud Motor (A61574)
2024 14ft Pairboat...
Caterpillar D8N Dozer Service and Parts Manuals (A63117)
Caterpillar D8N...
