Remote FEL joystick operation
/ Remote FEL joystick operation #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
I'm unsure if this method has been described here before, and it may not be applicable to everyone's tractors. With that said:
Today I used the FEL on my Deere to pull about 30 rods that had been driven into the ground about 3'. Only the top 4" of the rods was exposed, and I used the FEL bucket hooks and a chain to pull the rods out. Problem was, I had no way to operate the FEL while I was standing in front of the tractor keeping the chain tight so it would not slip off the rods. So I used a 10 foot long, 1 1/2" PVC pipe with a 90 degree ell on one end to work the joystick from the ground and raise the FEL.
DISCLAIMER: Any risk you assume using this method is just that, YOUR RISK. And don't even think about doing this while standing in the FEL bucket!!!!
/ Remote FEL joystick operation #2
I think this should be under the Safety titled as "This is not what to do." :thumbdown:
My :2cents:
/ Remote FEL joystick operation #3
I would have called a friend and said I need some help, want to operate my tractor?
All my friends were probably busy, my tractor is a hydro and the parking brake was locked, and I was standing well clear of the FEL bucket and wearing safety shoes. So, what makes this method so dangerous? I recall reading a post here some years back where another member described using ropes to raise and lower his FEL bucket...WHILE STANDING IN THE BUCKET....now THAT would be dangerous.
/ Remote FEL joystick operation #5
I would set the parking brake first.
If you had your tractor positioned correctly over a steel rod you wanted pulled, I see no reason that you could not use a long pole to push and pull the lever to raise and lower the FEL.
There is no reason to stand in front of the tractor.
I have reach around the rear to activate the 3pt lever trying to set the 3pt.
I have seen a device about 6 in lng and 3 in wide with a hole in it. You slip the adapter over the rod and as the lift goes up, the adapter tries to go straight and can't so it grabs the rod and pulls it up.
You could also make a hole in your bucket and place the bucket over the rod and tilt the bucket and lift and the rod will come up.
There are many ways to do this. A small clam shell device would work.
/ Remote FEL joystick operation #7
That is when I go inside and ask my wife for help. A few more years maybe the kids.
Perhaps I should explain my method more clearly: The steel rods were about 5/16" in diameter, and only about 4" above ground level. I used a length of 1/2" steel pipe to bend the exposed part of the rod at a 90 degree angle. If I used the chain link on the angle and stood by the seat to use the FEL, the rod would simply spin around and release the chain. If I stood on the steel pipe slipped over the bent part of the rod, raising the FEL a foot with the PVC pipe would yank the rod out far enough for me to bend it further so the chain link would not slip off, and I could walk back and use the FEL in the normal manner.
/ Remote FEL joystick operation #9
Piece of scrap metal and two holes:
If you don't have a thick piece, several thin ones stacked will work, too.
Bruce
/ Remote FEL joystick operation #10
Only if you were standing on a ladder in the bucket. ;-)
Sent from my iPad using TractorByNet
/ Remote FEL joystick operation #12
Bruce
But where's the fun in doing it tbat way? No danger at all, no possibity of getting cherished Darwin award!
So far, nobody has been able to explain what was dangerous about my way....to me, it was no more dangerous than the common practice of standing in back of the tractor and juggling the 3-point lift lever while you hook up an implement.
/ Remote FEL joystick operation #14
Its not, if you pay good attention, and don't get in the way of the bucket, you should be fine. As a matter of fact you didn't get hurt did you?. but the piece of flat stock would have pulled the rod with one person, and been slicker and easier, but hey you can try that next time.
2016 KUBOTA SVL90-2 SKID STEER (A65053)
2016 KUBOTA...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2006 John Deere 5425 (A64126)
2006 John Deere...
New/Unused Landhonor Quick Attach 3 Point Hitch Adapter (A65583)
New/Unused...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
