Tree Removal
/ Tree Removal #1
Bluest
Whitworth, Lancashire, UK
Yanmar F14D, DR Wheeled Trimmer
I was chatting with my neighbour yesterday and he asked whether I would consider removing some trees from my field (with his help) to improve the view from his house. I'd be happy to do this, it's good for neighbourly relations, they make mowing awkward and the fire wood would be handy. I probably wont get round to it for a few months, but it has got me thinking about how I would go about it.
There are something like 10-20 conifers ranging from 15 to 30 ft high. I've got a chainsaw, so why not just get on with it? Well, two problems.....
1) Once the trees are gone, I'd like to return the land to grass, so how the **** do I deal with 20 tree stumps left in the ground. I've heard of stump grinders, but the prices in the UK are way above my budget.
2) The trees are on an uneven slope of about 17 degrees, so getting a stump grinder, or any other substantial equipment down there is a bit hairy. I can just about get my tractor down there but I have to be careful to keep it pointing straight up or down.
I'm hoping there is some miracle solution that will cause the stumps to rot away in twelve months!....
/ Tree Removal #2
Shame about the slope because digging out the stump with the tree attached makes it quick and easy. The weight of the tree pulls the stump out and they fall over easily. Only problem is you need an excavator or a backhoe to do the digging.
When my parents lived in CA, they had a neighbor ask if he could remove a couple of their trees to improve their view. They didn't have a problem with him doing that, but insisted on a clean up deposit to make sure they hauled off the trees and didn't leave a mess for them to deal with. Once everything was done, they gave him back his deposit. I think it was a thousand dollars in cash that they insisted on because that's what they felt it would be worth to them to clean up the mess if that's what they where left with. Everything went fine and the neighbor was done in just a few weeks. It might have been that he was just the type of guy to do a good job, or it might have been that he wanted his money back and that motivated him to do a good job. Either way, having an incentive to finish it sure didn't hurt anything.
I think that if your neighbor wants the trees gone, then that's who should do the work and pay all the expenses in making it happen. I also think that getting a cash deposit to make sure it's done the way "you" want it done is also a very good idea.
I've seen people drill numerous holes into the stump and pour different stuff into them to speed up their decay. I don't know what they used, but sometimes it seemed to work, other times it didn't. I once took out a small stump with shove and axe, but it was only a 12 inch tree and I was full of energy back then. I don't think I'd ever do that again!!!
Good luck, I've taken out thousands of trees and don't miss a single one of them.
Eddie
/ Tree Removal #3
So if the field is on a big slope what kind of 'field' are you looking to have when the trees are gone? Are you planning to hay it? Let the field go wild? How big an area would the stumps encompass? You might be able to dig around each stump enough that you could cut close enough to grade that the stumps aren't an eyesore or real issue if all you're looking to do is let the field go fallow....
/ Tree Removal
It's mostly field already, with maybe 50 similar tress planted in various cluster around the perimeter. I mow just to keep it looking presentable and so I can easily walk the dog. It's a hobby to justify a tractor really! Long term aim is an apple orchard, but that's a dream at the minute. It's only a little over 1 acre. The gradient varies but the offending trees happen to be on the steepest part.
I don't think my neighbour is in a position to tackle the job on his own, the trees would stay if it came to that. Removing the trees themselves is not a problem for me, especially with a second pair of hands to help, I quite enjoy it. It's just the stumps that will cause me difficulty.
/ Tree Removal #6
I got rid of a small stump quite easily by just crosshatching the top. I had left about 4" sticking out of the ground and I was careful with the chainsaw as I didn't want to touch the soil with the chain. A year later I went back with a large hammer and just broke each crosshatch off and threw them into the garbage. They were well rotted and what was left of the 6-8" stump just disappeared. No fuss or muss or large equipment.
/ Tree Removal #7
Potassium Nitrate/Saltpeter will kill the roots of a tree pretty quick. Keep in mind that since 9/11 it is pretty hard (license checks and hoops to jump through) to get PN as it is also used in making explosives. The first number in fertilizer is the potassium, the higher the number the better, it will take longer but the stumps should rot away.
IF you use Potassium Nitrate, then you will need to drill down into the crown of the tree stump with a wood boring drill (1 1/2 bit) and fill the hole with the PN.
If you are dyslexic it is the first number, for the rest of us it is the last number. Ingredients in order of number are N (nitrogen) P (phosphorus) K (potassium)
/ Tree Removal
Thanks again all. So no miracle cure for tree stumps! I do like to do things myself, and hate being defeated, but 20 stumps might be a bridge too far. Having thought about it, and assuming the slope doesn't put him off, I know a man with an excavator who charges £150 a day. Would likely leave big holes, but I could easily back fill the holes afterwards.
Should have added, I'm not a big fan of putting chemicals in the ground if I can possibly avoid it, but I'll look into how easy/cheap the chemicals are.
/ Tree Removal #10
I have a friend that has a stump grinder that has rubber tracks. I don't think the slope would be an issue if they approached the stump on the low side. You said they cost for this was high. Get the neighbor to pay 75% +/- for the stump grinding.
If you can get an estimate on cost to grind the stumps tell the neighbor this is the only way you can agree to have the trees cut. And if he agrees to pay get the money before cutting. You know some people will pay a million dollars for a view.:)
/ Tree Removal #11
Try Kingwell Holdings, tell them what you want, don't let them talk you into using a mulcher to grind out stumps,it don't work. 17 degrees! that's almost flat.
Good luck
/ Tree Removal #12
depending on the "tree" locations ...
one could use a rope tied towards the top of the offending tree, tie the other end to a winch / come along / etc ... then tie the winch to the base of a good tree nearby ...... winch the top down and rip the roots out of the ground ..... as the tree leans over , beat the root ball a bit to dislodge the soil , then cut the roots with a bow (swede) saw /or axe/ as they come up .... you should be able to pull most of them over and have 1 or 2 trees left standing ...
BTW , diesel poured into holes drilled into the cambium layer of a stump will kill it ....
/ Tree Removal #14
You can take a cordless drill and say a 3/8" drill bit. Drill numerous holes preferably to ground level. Get some pure nitrogen and pour into the holes. It will burn the stump out fairly soon. Usually "Weed-N-Feed" products are pure nitrogen and no phosphorous and potash. I've use it on several dozen stumps.
/ Tree Removal #15
They're only 15-30 ft high. After a good wet spell put a chain or cable about 2/3 up them and pull them over, root ball and all.
/ Tree Removal
I think that last suggestion has promise. The promise of £250 from a home video show when I fall out of the tree trying to attach the cable, pull the tree down on top of me or catapult my little tractor into the next postcode!
/ Tree Removal #17
Those stumps shouldn't be very big. Over here, the bigboxfarmstores sell a 3 point hitch implement (someone help me here with the name) for about $100 USD that's just a single, one tooth scarifier that penetrates about 1 to 1.5 feet below grade and can sever the roots on each side of a stump if you aren't too close to the stump where the roots are too thick. Those trees might blow over in the next windstorm afterward or you could help them along a bit, just for fun. Your neighbor could buy it for you and you could both use it for future projects. One good use for them, with a little modification, is burying cable or water lines.
Edit: SUBSOILER was the name I was trying to think of.
/ Tree Removal #18
The easiest way is to tell the neighbor he has permission to remove your trees, stumps and all, leaving you a clear field.
Bruce
/ Tree Removal #19
Bruce
I agree. If the neighbor wants to improve his view, then he should pay to have it done. Nice, neat and tidy too.
/ Tree Removal #20
No, it wont. it will kill everything. Diesel isnt a poison, its a light oil. It basically smothers everything from micro organisms up and will create a dead zone, although it will do an excellent job at preserving the stump (that and waste oil are great at making wood last)
Diesel and waste oil preserves stumps!!!!!
Getting the ground around the stumps soaked with water will lessen there hold by about 30%. Cut em high (6 foot high trunks) and leave them for a year for the smaller roots to die and they will be much easier to uproot to.
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2016 JEEP PATROIT (A67148)
2016 JEEP PATROIT...
2004 BOBCAT MT52 STAND ON SKID STEER (A65053)
2004 BOBCAT MT52...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
