Your towing rigs and trailers
   / Your towing rigs and trailers #1,671
That is why I am registering my 95 F350 dump as a F-superduty with a 15k GVW
   / Your towing rigs and trailers #1,672
Nice, if you have that option.
Here, over 9,999#, you are looking at a commercial annual safety, which triggers other associated cans of worms.... :mad:
Rgds, D.
   / Your towing rigs and trailers #1,673
The killer is the GVWR. Weigh that truck and you will find 1500 to 2000# is about all it can haul "legally".
My friend has the same exact truck. Is yours a electric hydraulic pump or pto driven? His is electric and a few times we have had yo shovel off some before it would dump.
Chris
True, but it's fine for what I need it for. I would not be able to plow my driveway with a dump trailer or dump sand while plowing, haha! It's an electric hydraulic for the dump, haven't had the chance yet to put it to work.
   / Your towing rigs and trailers #1,674
Rgds, D.
I already have my PICKUP registered for 26k and it is $400+ a year. But it is what it is. Any anything over 17k NEEDS a BI- annual safety inspection(commercial or not)
   / Your towing rigs and trailers #1,675
Here's my tow setup.
Truck: '09 Ford Ranger FX4 w/ 5spd, 3700 lb trailer capacity, & load springs in rear.
Trailer: 1700 lb factory cap. Engineered 2' extension, reinforced frame, new bearings & tires.
Tractor: '75 Cub Lo-Boy 185, 1650 lb (front weights included)
attachment.php
attachment.php
attachment.php
   / Your towing rigs and trailers #1,676
Nice looking setup there LFEngineering!
   / Your towing rigs and trailers #1,677
It gets a little weird here at times. Guys have gotten grief over pulling a brand new 1200# single axle SnowBear (Home Depot, here) trailer behind a properly commercial stickered (yellow tag here) F450, because the #1200 trailer didn't have IT'S commercial yellow sticker !
I'm for real safety on the roads.... the tax grab stuff, not so much.....
Rgds, D.
   / Your towing rigs and trailers #1,678
374230d1399541612-your-towing-rigs-trailers-p5070046-jpg
374231d1399541612-your-towing-rigs-trailers-p5070047-jpg
374232d1399541612-your-towing-rigs-trailers-p5070048-jpg
Looks like a really nice balance between tractor capacity vs. trailering weight. On an obviously well taken for tractor :thumbsup: .
For the roads around here, you'd be kind of on the edge weight wise - that trailer with that load would take a real pounding. Single axle trailers here have the advantage of being somewhat less of an inspection target, so they do have that going for them....
Your attention to detail comes through in your post..... I'll emphatically state the obvious and say keep an eye on those trailer tires.... they don't seem to be making 'em like they used to ! Though, that's an ST tire issue in general, not just with single-axle units....
An efficient combination of equipment :thumbsup:.
Rgds, D.
   / Your towing rigs and trailers #1,679
Agreed. It's not the most ideal setup. I try to stay off the highway and no further then 20 miles from home. Thankfully I only need to move the tractor a few times a year to help out friends and relatives.
I've been toying with the idea of fabricating a replacement trailer, but just don't have the time right now. Figure I'll keep hording parts until work slows down and knock it out in a weekend or something.
   / Your towing rigs and trailers #1,680
I tried to word what I said :) so it didn't just come across as criticism.... you obviously are on top of what is going on - good to see, as many (non-TBN) folks pay little attention to a vehicle, and even less to a trailer.
Tires are a weak link, as are bearings. Bearings are cheap enough to replace at inspection, tires are the wild card. I've posted a link somewhere on here about a Tire Rack article that recommended inflating ST tires to over the Max inflation rating, for high speed highway use. I'd always kept my ST tires close to the Max inflation, after reading that, I make sure that they are exactly at Max pressure.
This has reminded me of one of my 'RoundToIt's..... on a rainy day, I need to get back to researching/validating that over-pressure claim....
Rgds, D.
8ft. S/A Utility Trailer (A55853)
8ft. S/A Utility...
2014 Ford Mustang Coupe (A55853)
2014 Ford Mustang...
JCB 409T4 WHEEL LOADER (A52707)
JCB 409T4 WHEEL...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
UNUSED RAYTREE RMLL60 60" HYD POWER RAKE (A57193)
UNUSED RAYTREE...
LANDPRIDE BB2560 5' BOX BLADE (A57192)
LANDPRIDE BB2560...
