battery not charging
/ battery not charging #1
biff henderson
Hi,
I have a 1650 cub cadet that will not charge the battery. Does anyone know what causes this?
/ battery not charging #2
Here are a couple of pages from the Kohler service manual on the charging system. I hope it helps.
/ battery not charging #3
Just follow the troubleshooting chart that was uploaded and it should lead you to the problem The most likely and easiest to change is the regulator. If you have 28 volts AC or greater going in and it's not charging the battery 13.5 - 14.5 volts the regulator is probably bad. I had to replace one on my 1450.
Bob B.
/ battery not charging #4
Sometimes the alternator coil itself or the wires go bad. Those wires are easily kinked, too. No fun at all because you have to pull the engine to replace it.
While you're looking at this, check your engine ISO mounts, too, cuz they are a routine failure point.
/ battery not charging #5
I have an older model cub cadet. It runs great till I engage the clutch for the blades, Then the alternator light comes on and stays on till The clutch is disengaged. Where is the regulator located and could this be the problem? model number is 144 653 100
/ battery not charging #7
How old is the battery? I had the same problem , battery was no good , dead cell or cells , just a thought .
/ battery not charging #8
Thats what i was thinking,you only get 2-3 years before they have replace them.
/ battery not charging #9
I have one that I'm going to get bronzed when it dies. 2004 Cub 3235 with the original sealed battery. I just started putting a battery tender on it over the winter the last couple years. Started right up a couple weeks ago for the first mowing this season.
Bob B.
/ battery not charging #10
I just fixed the same problem on my cub 1250. In my case it was the stator located under the flywheel. You can download the service manual online. It has the test procedure clearly explained. If you are not getting 20+ ac volts from the left and right terminals of the regulator with the engine running then you most likely have bad wires or stator. I paid around $35 for a new stator on eBay and installed it myself. If you have another kohler engine swap regulators to test. Good luck.
/ battery not charging #11
I would Bronze that Baby.
Bob B.
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
2018 Deere 670GP (A64126)
2018 Deere 670GP...
28 Gauge R Panels (A65640)
28 Gauge R Panels...
Giyi GY-BK56 (A64127)
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2008 EZ-GO GAS GOLF CART (A63276)
2008 EZ-GO GAS...
