Looking for my first chainsaw: Stihl MS251 or Jonsered 2255?
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #141
Ok so here's a Dolmar question...
It's there an online source for chains? I'm having a hard time locating some
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #142
Should be able to get anything you need from Bailey's online. They have a calculator of sorts to determine chain needs and part numbers.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #143
This is probably a dumb question ...
Looking in the manual, it specifies that the PS-510 & 5105 use the same chain.
Sprocket pitch is .325 or 3/8
7 teeth
Chain pitch/gauge is .325- .050 or 3/8 - .050
I found a chain at TSC (Oregon made) 20" , that lists the Makita version of the Dolmar PS-510. It's a 3/8 chain. My Dolmar came with the .325 chain.
So ... Will this chain fit my saw & bar? Do .325 & 3/8 chains require different bars?
I only ever used direct replacement .325 chains when I had my Husky 450, so I never gave a thought to different pitch or gauge.
Thanks...
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #144
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #145
7 teeth
Thanks...
Yes you will need a different bar for 3/8 chain.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #147
Same sprocket?
No. You need a 3/8 rim sprocket, 3/8 bar and 3/8 chain.
Also make sure the bar and chain are the same gauge, like .050.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #148
Or just get Stihl or Oregon chain in .325, .050, for the 20" bar you have now.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #149
Ok. Any reason to go with a 3/8 chain over a .325 chain? I cut and limbs a 16 inch tree today, & I was very happy with the performance of this saw. Definitely an improvement over my previous 450
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #150
I would, but I haven't had any luck finding some listed for my saw
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #151
The only reason to use 3/8 chain on that saw, is 3/8 has less teeth which makes it a little quicker to sharpen. I personally like .325 better than 3/8 on a 50cc saw. Takes more power to pull 3/8, .325 will likely cut faster.
Go to a real saw shop and ask for .325 .050 20" chain. Or go to Baileys.com and look it up.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #154
Use the Oregon chain and bar selector. They have one for homeowners and one for pro's. The one for homeowners is reduced kickback chains. If you don't have much experience running a saw a reduced kickback chain may be better for you. I have one on my Stihl MS170 and my 024S MS 260 hybrid. Both chains cut good. Is your saw rim drive or spur drive?
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #155
I buy most of mine on e-bay. I use Oregon brand. I have bought from baileys ,but found them to be some what higher in price with shipping
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #156
Baileys sells some nice stuff but I have also found there prices and or shipping to be high. Usually the shipping is the deal breaker. They have been doing flat rate shipping recently.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #157
7 teeth
Thanks...
Why switch? I would stay with the 0.325 over the 0.375 (3/8") on that saw. I use the 0.375 on larger saws that have more power.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #158
No, I didn't have any deliberate intention to switch ... the 3/8" was just what I'd found at my TSC.
However, I did end up ordering some online last night. Amazon has em for under $25/shipped.
Thanks for the info y'all
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #159
Just to clarify, aren't the 3/8 chain cutting teeth larger than the .325 chain teeth ? Is .325 the size that come on the poulans,etc, like they sell at the box store ??
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #160
My Stihl MS261 50cc has 0.325. Pretty normal for 50cc
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
2022 New Holland C327 Compact Track Loader (A56438)
2022 New Holland...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
