Looking for my first chainsaw: Stihl MS251 or Jonsered 2255?
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #141
Ok so here's a Dolmar question...
It's there an online source for chains? I'm having a hard time locating some
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #142
Should be able to get anything you need from Bailey's online. They have a calculator of sorts to determine chain needs and part numbers.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #143
This is probably a dumb question ...
Looking in the manual, it specifies that the PS-510 & 5105 use the same chain.
Sprocket pitch is .325 or 3/8
7 teeth
Chain pitch/gauge is .325- .050 or 3/8 - .050
I found a chain at TSC (Oregon made) 20" , that lists the Makita version of the Dolmar PS-510. It's a 3/8 chain. My Dolmar came with the .325 chain.
So ... Will this chain fit my saw & bar? Do .325 & 3/8 chains require different bars?
I only ever used direct replacement .325 chains when I had my Husky 450, so I never gave a thought to different pitch or gauge.
Thanks...
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #144
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #145
7 teeth
Thanks...
Yes you will need a different bar for 3/8 chain.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #147
Same sprocket?
No. You need a 3/8 rim sprocket, 3/8 bar and 3/8 chain.
Also make sure the bar and chain are the same gauge, like .050.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #148
Or just get Stihl or Oregon chain in .325, .050, for the 20" bar you have now.
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #149
Ok. Any reason to go with a 3/8 chain over a .325 chain? I cut and limbs a 16 inch tree today, & I was very happy with the performance of this saw. Definitely an improvement over my previous 450
   / Looking for my first chainsaw: Stihl MS251 or Jonsered 2255? #150
I would, but I haven't had any luck finding some listed for my saw
S/A Utility Trailer (A59231)
S/A Utility...
More info coming soon! (A56859)
More info coming...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2010 Case 580N (A60462)
2010 Case 580N...
