Another toolbox solution (L3400)
/ Another toolbox solution (L3400) #1
vulcancowboy
Gold Member
Duncannon, Pennsylvania
Kubota L3400 HST
I looked at several toolbox ideas and finally came up with this one. I happened to have the toolbox laying around (that's why it is so dirty). I mounted it on the cross member that runs between the fenders by welding 2 1/8" by 1" x 5" pieces of flat steel across the support and then running bolts down through the inside of the tool box to attach it to the cross member. So far, I'm pretty happy with it. I just needed someplace to keep a few tools, pins and spare shear bolts for my bush hog. Maybe this will help someone else who is looking for toolbox ideas.
/ Another toolbox solution (L3400) #2
Mine had one in the same oocation, although a bit smaller and steel.
/ Another toolbox solution (L3400) #3
Mine had one in the same location, although a bit smaller and steel.
/ Another toolbox solution (L3400) #4
Looks good to me.
/ Another toolbox solution (L3400) #5
I need to do something similar. I need to relocate the SMV placard also, I'd like to put it on the rops.
/ Another toolbox solution (L3400) #6
I usually take the smv triangle off unless I'm traveling on the road, they're a pia.
/ Another toolbox solution (L3400) #7
My SMV and toplink decided they both wanted to be in the same place at the same time. SMV lives in the barn, now. I don't drive the tractor on the roads here - there's no shoulders and people just don't pay attention.
Nice toolbox, Vulcan - is that a reciprocating saw case?
No, it is a Craftsman toolbox, one that is supposed to fit under the seat of a truck.
/ Another toolbox solution (L3400) #9
My L2800 came with a small toolbox in the location you mounted yours. It was only about 12"L X 3"W X 3"H. I found this Speeco at Rural King that was 20"L X 6"W X 5.5"H. Had to drill a hole to adapt it and had to move the bracket on my SMV triangle.
2020 WESTERN STAR  4900 TRI-AXLE (A65643)
2020 WESTERN STAR...
6' Howse Bush Hog (A62613)
6' Howse Bush Hog...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
Woodland Mills Sawmill (A65579)
Woodland Mills...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
