hydraulic fittings
/ hydraulic fittings #1
chainsawnut
Member
victor harbor south australia
Not yet
Hey all still slowly progressing with acquiring bits and pieces but I would like an answer to a question. Somewhere I read (possibly here) about fittings that shouldn't be used and I can't remember i fit was brass or galv that was a no no. But there is also a possibility my pain killers may have been kicking in and I imagined it but I would like to clarify this thanks pete
/ hydraulic fittings #3
For high pressure hyd, use steel only.
NO galvanized water fittings or black pipe.
No brass or copper.
Discount Hydraulic Hose
Pipe Fittings > Discount Hydraulic Hose.com
JJ, don't forget nipples, they need to be XH (Schd 80) seamless also. That can be the weak link. Those black fittings at the hardware store are malleable iron (125# pressure rating). Hydraulic shop or industrial supply place or the most reliable sources. The average person has no clue about this stuff. I bought a used log splitter, the guy was selling it because he had repiped it for a new valve and used malleable fittings and sched 40 seamed nipples and couldn't figure out why the fittings kept breaking. Made real deal on that.
Ron
/ hydraulic fittings #4
That is one heck of a way to get a deal for yourself and maybe save his life at the same time. Maybe JJ could send him some of those fluid injection injury photos?:eek:
/ hydraulic fittings #5
I actually told him his problem, guess he got scalded a couple times and did not want to mess with it anymore. It cost me $50 to but new fittings and an hour to re-pipe it again. I was able to leave out several fittings also. Works fine for me.
Ron
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
Wolverine 84" Quick Attach Snow Push (A66285)
Wolverine 84"...
(4) Hydraulic Cylinders (A65640)
(4) Hydraulic...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
100 Gallon Galvanized Water Tank (A65579)
100 Gallon...
