   / Your last generator Maintenance Run #221
Can't see the data.
Chris
   / Your last generator Maintenance Run #222
There is a pdf file that you click on to open.
Can you see the file??
It worked for me, I could open the pdf from the link.
I'm going to print that out later to review in detail.... just looked at your bottom line.
Considering the elevated price of diesel fuel in the USA, the Yanmar did quite well in $ terms.
Thanks a lot for doing those tests, but even more so for spending the time beating on your computer to post the results !
Good stuff !
Rgds, D.
   / Your last generator Maintenance Run #224
Not from my Ipad. I hate Apple stuff but it's what my work makes us use.
I will try from my phone or computer later.
Chris
   / Your last generator Maintenance Run #225
Interesting. They are closer than I would have expected.
I always like to see data....
One thing that data highlights is how much fuel gets chewed up at Idle - both gens. Going to 75% (ish) load only doubles consumption from Idle.
I've been doing a little bit of work lately with portable batteries and inverters. Useful for lots of things, but esp. for running light loads for extended periods, then just running a gen loaded up, to recharge the battery.
Thnx again 90cummins !
Rgds, D.
   / Your last generator Maintenance Run #227
Howdy,
Now with the weather changing. It's time to change out the fuel. Siphoned out as much as possible, ran all generators for at least 30 minutes with load. Put fresh 100% gasoline with sta-bil back in all. Trickle charge set for each battery unit. Ran PTO unit for 15 minutes with small load (4k) All set for warm weather. :cool2:
Howdy,
Spring Prep - Done ! :thumbsup:
Rgds, D.
Date: May 03/14
Generator: 2kw Briggs
Activity: unscheduled run.... ran the main fridge for about an hour, due to a power outage.
Final Fueling notes: filled w. NonE gas. Red Stabil and Seafoam added already in fuel can.
Maintenance notes (Done, or Required):
Started 2'nd pull w. partial choke. Need to slightly re-work tank cap breather.
Oil level good. Temperature 9 deg C.
Rgds, D.
Date: May 20/14
Generator: 7kw Briggs
Activity: Vacuumed entire van with shop vac.
Electric start used, full choke second start, after partial choke first start. Oil level good. Battery registered 13.02v after starting, and before being put back on its charger. Temperature 19 deg C.
Rgds, D.
2019 John Deere 85G Midi Excavator (A56857)
2019 John Deere...
Yamaha Rhino 450 (A57149)
Yamaha Rhino 450...
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A58214)
2012 CHEVROLET...
2014 Komatsu D51PXI-22 (A55272)
2014 Komatsu...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
Giyi Tree Shear (A57149)
Giyi Tree Shear...
