rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,979
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Machine is a JD310SG.
thanks, rScotty
thanks, rScotty
If anything ever goes wrong in any way. You can be liable in a lawsuit. Even if the backup alarm was not directly involved. Disabling the backup alarm displays a wanton disregard for safety in general.
OK, I fixed it. The horn turns out to be a square plastic trumpet type mounted under the BH swing pivot. Easy to look at and even to touch, but near impossible to unbolt....and the consequences of cutting a wire didn't seem worth risking.
So I took the simple approach and stuffed an old sock in it and held it in with a strip of Gorilla tape across the open end.
Bingo! Problem solved! Total time about 2 minutes and cost near nothing. Probably take less than a minute to reverse it. I thought the sock might muffle or reduce the sound, but to my surprise it completely silenced that annoying and - IMHO - attention-robbing beep.
rScotty
