oil pan drain bolt
/ oil pan drain bolt #1
bubbu55
North Creek N.Y.
Kioti CK35 HST
One side of my oil pan is seeping out of the drain bolt. Is there a certain type of washer to use along with the bolt? The leak is very slow so I think it's just a problem with the washer. I have a Kioti CK 35 2008. Any suggestions would help. Thanks
/ oil pan drain bolt #2
Pull the bolt out and make a new gasket out of card stock. IF you don't have any card stock, then one of those file folder thingys will work as well. An old business card will work as well.
/ oil pan drain bolt #3
Most good auto parts stores will have a selection of copper crush washers to match your drain plug.
When I can't find mine I make one from some 3/32 PVC sheet that I have on hand but do prefer the copper crush washers.
/ oil pan drain bolt #4
One other thing, I don't know about the CK series but my DK pan is aluminum. So don't tighten it too much or you will be sorry. Don't tighten it too little or you will be sorry too. But the bolt is steel, and the pan is aluminum threaded, so act accordingly.
/ oil pan drain bolt #5
I was in the hardware (nuts & bolts) section of Ace Hardware just the other day and discovered they have trays of various vehicle and equipment drain plugs and washers. Next oil change, I'll bring in mine to match them and get spares to have on hand.
Thanks, I'll try one of the solutions here. Thank God it's nothing serious.
/ oil pan drain bolt #7
No, it is not serious. Reminds me of something I read on an aerosol can label last year.
I was in a tire shop having some work done and was browsing some products on display just to pass the time. On one can of wheel cleaner the label said something to the effect that if the stains remain on the wheels, "seek professional help".
Luckily, you can handle this one on your own.
/ oil pan drain bolt #8
A place like Advance Auto will have small packs of assorted drain plug washers, usually on a floor display aisle. I try and keep one or two packs of those around, I've always got something around they can be used on, and saves making a drive just for a 20cent washer when you take something apart and find that the washer is past it's due date....
Rgds, D.
/ oil pan drain bolt #9
winning combo.. steel plug and aluminum pan.. DOH! :)
/ oil pan drain bolt #11
One other thing, I don't know about the CK series but my DK pan is aluminum. .
I hope it has a shield over the oil pan from whatever could hit it from below. I have run over T posts that I did not know where there when clearing brush. Backing up, they tend to lodge under the tractor and bend into a U. I am not a a fan of anything aluminum under a tractor.
/ oil pan drain bolt #12
Nope, it is aluminum. but I don't see how a steel oil pan would stop a T post either unless it was really thick. If you are going to run over T post' you need to build some shields.
/ oil pan drain bolt #13
Well I haven't had any trouble yet, but if you got "jiggy" with the wrench, you sure could.
that hard drain plug will win against that soft pan every time.
Sometimes I see where a soft pan has a steel insert for the drain plug.
IMHO.. the best bet would be a soft plug and harder pan ( or insert ).
If they set it up correctly so that it clamps a good oring or washer.. should be fine i guess.
/ oil pan drain bolt #14
yep.. most steel pans are sheet metal and thin.. a heavy cast pan like a structural member under a ford N MIGHT do ok...
/ oil pan drain bolt #15
Actually the best I could tell it did lodge on the steel pan and resulted in a good scrape but no real damage. Had I known the T posts were in the brush I would not have backed up. But you don't know what you don't know.
Does anyone know the torque rating on the oil pan bolts for a 2008 CK35? Better yet is there a place to look at the shop manual in cyberspace?
2024 Ranger XP 1000 North Star (A62679)
2024 Ranger XP...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
GSI Grain Dryer (A64127)
GSI Grain Dryer...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
