LS XR3037HC Play in the steering wheel?
   / LS XR3037HC Play in the steering wheel? #1
Triboman
Easton CT.
Mahindra max 28xl + LS XR3037HC
Newb here with a quick question. Just bought a new LS XR3037hc and when I test drove it I noticed some play in the steering wheel. The dealer told me this was normal in LS tractors and it was nothing to worry about. I only noticed after I had shut the tractor off. Was wondering if any LS XR3037 owners noticed this also? Thx..
   / LS XR3037HC Play in the steering wheel? #2
Welcome to TBN...
I have the same tractor. Only about 16 hrs. on it but no problem with play in the steering wheel that I have noticed. Will check on Sat. while using it but think I'd remember if it had any play.
Welcome to TBN...
Thanks.. I only noticed when the tractor was off.
   / LS XR3037HC Play in the steering wheel? #4
Well, you got me curious so I went out to the garage and checked the steering play. With the engine off the wheel moves about 4". Is that the play you have? On mine that goes away when the tractor is started and the hydraulic steering pump is running. When running, the slightest movement of the wheel will move the wheels.
Thanks a bunch! Yes the play is about the same as you described. I'm taking delivery on Monday and wanted to be sure this was common. I will double check it when the tractor is running just to be sure.. Super excited to get my first cab tractor!
   / LS XR3037HC Play in the steering wheel? #6
George is right, that is normal, nothing to worry about!
   / LS XR3037HC Play in the steering wheel? #7
Sounds the same as mine.
   / LS XR3037HC Play in the steering wheel? #8
Normal. It has hydrostatic power steering.
They all do that when the engine is off.
Thanks Gentlemen..
Got the tractor today and it was as everyone described. As soon as you start the tractor the play goes away.. LS TRACTOR 009.jpg
   / LS XR3037HC Play in the steering wheel? #10
I get mine Saturday..... can't wait
2022 RK25 PERMORMANCE SERIES TRACTOR (A54756)
2022 RK25...
UNUSED JCT 84" HYD DOZER BLADE (A54757)
UNUSED JCT 84" HYD...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A54607)
1995 PETERBILT 377...
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
