Lost all the coolant today
/ Lost all the coolant today #41
Just the FEL at this point. Still working on getting a box blade. Used the "float" quite a bit with the bucket. Works ok, but I need a box blade for sure.
So are you backdragging?
Yes. I tried to drop it from the bucket as evenly as I could either moving forward or backward. Then back dragged the bucket over it to spread it.
Worked alright. It looks fine, but is a bit lumpy. Ha
/ Lost all the coolant today #43
Let me give you a couple of pointers, (worth exactly what you paid for them:) )
You can angle the lip of the bucket down to be more aggressive and roll up a little pile of gravel to spread and then pull the stick back towards your leg when you wish to feather out that little working pile. As you go backwards the little pile on the bucket edge will fall into the low places and it will scrape off the tops of the high places, you determine how aggressive this action is. I have found it is best to go backwards at a fairly fast pace. I use Med range most of the time. One must be careful not to have too much angle even to start with or you will move too much materiel in the travel direction. I often swap directions to prevent an overall loss of material from the starting point. When I have it looking pretty good, I go over it with the bucket almost level to move very little material, swapping directions repeatedly. I have been able to achieve very good results doing this. I don't think it is as fast as a box blade, but I believe the results are as good.
Let me give you a couple of pointers, (worth exactly what you paid for them:) ) You can angle the lip of the bucket down to be more aggressive and roll up a little pile of gravel to spread and then pull the stick back towards your leg when you wish to feather out that little working pile. As you go backwards the little pile on the bucket edge will fall into the low places and it will scrape off the tops of the high places, you determine how aggressive this action is. I have found it is best to go backwards at a fairly fast pace. I use Med range most of the time. One must be careful not to have too much angle even to start with or you will move too much materiel in the travel direction. I often swap directions to prevent an overall loss of material from the starting point. When I have it looking pretty good, I go over it with the bucket almost level to move very little material, swapping directions repeatedly. I have been able to achieve very good results doing this. I don't think it is as fast as a box blade, but I believe the results are as good.
Thanks for the tips. I was bringing back some little piles, as you describe, but I had the bucket in the float position most of the time. Either with a pretty sharp angle, or fairly flat. Having just messed up one of the cylinders on the loader, I kept thinking if I'm not in float, I'll break something again. I was doing better towards the end. Maybe a little progress on the learning curve. I'll try it without being in the float mode and see if that helps.
Thanks again.
/ Lost all the coolant today #45
Thanks again.
Well I meant doing all of that in float, and please don't put a severe angle on the bucket either. about 15 degrees or less, usually less. I will point out I have been doing this for over 20 years and haven't broken anything yet. You will not have good results if you are not in float, you will gouge part of the time and miss the ground part of the time.
/ Lost all the coolant today #46
What do you suspect was the culprit of damaging the cylinder?
Ok, I think I get it. The only confusing point for me know is, "pulling the stick towards me to feather the pile." I thought you couldn't touch the controls when in float.
I don't think I'll be breaking anything else again,, soon. (Famous last words, ha)
Thanks again.
Trying to lift when I've got the bucket where it absolutely can't come up. Like against a stump, or with too big of a load. Some of the trees I've been taking down are pretty big.
Got to slow down, take my time, enjoy it.
/ Lost all the coolant today #50
Thanks again.
When in float you cant raise or lower the lift, but the curl/dump is fully operational. You keep you hand on the stick and adjust the bucket angle in small increments to be more aggressive in your scrape or "feather" it out so it is smooth. Think of it exactly as spreading butter on a piece of toast. It takes some skill and time to learn how to feather out and make it all smooth, but you will get it. Just practice.
/ Lost all the coolant today #51
The Bobcat mechanic did say the cylinder was defective. I believe where the hydraulic line attached. So maybe it wasn't me..
I am fairly certain you did not break a cylinder by going into relief. If cylinders broke that easy, I would break 10 a day by trying to lift something the tractor would not lift:) I wish I could spend a day with you and show you some things. I know we would have fun, and I am sure it would help you out a bit. Ask lots of questions when you don't fully understand something and we will try our best to help.
Thanks!! I'd like to meet up with you guys some day to discuss a million things. From FEL tips to brush cutter set up, and I haven't even touched maintenance yet! Following the OPs manual though.
Glad I didn't break that cylinder. It was one of those days, when I cracked the radiator, just figured I'd messed that up somehow also.
Enjoying the morning out in the field this morning, but looking for a gobbler to come by.
/ Lost all the coolant today #53
were you planning on sending a load of No. 5's his way?:)
/ Lost all the coolant today #55
Good tips on leveling. I just did about 1/2 acre that way, however there is one last trick. I take my drag field harrow and turn it upside down and drag across the area to do the final leveling. You can also use a section of chain link fence that has something to weight it down. I made one using 2 old fence posts and used fencing staples to hold the chain link in place. You run it fencing down with posts on top. Works great, especially for covering broadcast seed.
If your seeding the last step is to wheel role. I also do that before running the harrow above over i the area.
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2013 PROFAB 200BBL CRUDE TANKER (A65643)
2013 PROFAB 200BBL...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
Skeleton Backing Plate (A62679)
Skeleton Backing...
