Bucket hooks with round top bar?
   / Bucket hooks with round top bar? #13
I agree with Gary's idea (post 7) the best. Jerry's idea (post 6) is also good. Either will work for adding hooks.
Wow! Thanks for all the replies and ideas - there is a lot to sort through and try to visualize.
   / Bucket hooks with round top bar? #15
^^^ Like ^^^
Have you ever had a chain pop out of the slot? thinking a 1/2" wide x 1/8" deep horizontal groove ground out at the bottom of the slots would grab the chain, but also thinking that would weaken the attachment. hmmmmmm...
No, never had the chain come out unless I wanted it to. I'd hesitate to make the chain more captive than it is, because as mentioned earlier sometimes it's nice to be able to roll the bucket and not dismount to disconnect.
I use the same slotted steel to mount the brush forks. The forks are welded to a common angle that slips over the bucket lip. A heavy binder ratchet connects to a bridle chain on the forks.
   / Bucket hooks with round top bar? #16
I have the same bucket on my TC30, I mounted the hooks on the flat behind the round top. So far no problem.
I think I have most of the ideas summarized below:
  1. Side of bucket
  2. Side of bucket attachment arms
  3. Flat welded on top of bar back to bend in bucket
  4. Slotted angle iron
  5. Slotted channel
  6. Angle iron in line with loader arms (I'm having trouble visualizing this one)
  7. Angle iron between loader arms
  8. Bar stock spacer
  9. Kubota hooks
  10. Channel behind round bar
  11. Channel on top of round bar
  12. Direct to bucket on flat behind round bar
#12 was part of my original question - why not just put the hooks on the bucket and drape the chain over the bar. It sounds like a couple owners have bent the bucket that way so I will avoid. I'm thinking I will start with the slotted angle iron - mainly because it seems easiest for me, the idea is somewhat novel and intrigues me, and if it doesn't work out it will be easy to remove and do something else.
One question though Chim - why three to five slots in each angle? I can see two for your brush forks or to manage excess chain, but what do you use more than two slots for?
Thanks to all. I will post pictures and let you know how it goes after I get it on.
   / Bucket hooks with round top bar? #18
...........................One question though Chim - why three to five slots in each angle? I can see two for your brush forks or to manage excess chain, but what do you use more than two slots for?...............
The extra slots are mostly for keeping extra chain out of the way. There are times when I'll pick something with only one chain. Like Wednesday evening I picked the rear blade to put it in the shed. For storage it sits on the face of the blade with the frame locked so it takes up less space. Dropping the extra chain into the spare slots kept it out of the way. Without plenty of slots, extra chain would probably end up being carried in the bucket and getting dumped out when I roll the bucket.
There are times when I want to pick something and keep it parallel with the bucket using two chains. Then the outside angles are used and there are still plenty of slots to drop the extra chain into.
The bucket doesn't roll far enough to dump the load and the chains won't slip out of the slots until the top of the bucket is roughly as low as the connection to the item being picked and moving away from it.
Making decent slots was just a matter of drilling holes and sawing to them from the edge of the angle.
   / Bucket hooks with round top bar? #19
Hey Chim, when you get a chance, can you take a snap-shot of the underside of that fork set-up.
I have similar forks, and I like your set-up, I'd like to see what it looks like underneath.
Thank's, Rick
   / Bucket hooks with round top bar? #20
Thank's, Rick
The loader and forks are off now, but here are a couple shots I took a while back. The chain is welded to two places on the back of the fork frame to form a loose loop. The load binder grabs the chain loop.
UNUSED FUTURE FT-CW59 59" HYD COMPACTION WHEEL (A57193)
UNUSED FUTURE...
8ft Flatbed Truck Body with Axle (A55852)
8ft Flatbed Truck...
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A57192)
UNUSED LANDHERO...
UNUSED SDLANCH SDLL50 STAND ON SKID STEER (A57192)
UNUSED SDLANCH...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
