Do your own Fluids and Filters on a BX
   / Do your own Fluids and Filters on a BX #291
Re: Do your own Fluids and Filters; SAFETY ISSUE
Good advise.
Ky is a coal mining state but has more deaths in farming than coal mining. Most of the farming deaths are tractor/equipment related. Be careful around machinery at all times. It only takes a second to mess up.
Ouch!!! Just came across this post---unbelievable.
   / Do your own Fluids and Filters on a BX #292
Good advise.
Tractors are very useful and can be dangerous with the lose nut behind the wheel.:eek:
For the BX25 changed his own fluids guy.:D I think reading this first would have been helpful.
   / Do your own Fluids and Filters on a BX #296
I have a BX25D I bought new in 2013. I don't use it as much as some but earlier this year the clock was rolling up on 50 hours so I did an oil & filter change and naturally greased everything.
This is what I used.
Mobil 1 5W-40 Turbo Diesel Synthetic Motor Oil
Kubota Oil Filter
Kubota Fuel Filter (2)
In the fall I'll change the hydraulic fluid in both the main reservoir and the front drive axle. I'm switching over to Amsoil full synthetic and I think should give a bump in hydraulic performance especially during the winter months.
Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30
   / Do your own Fluids and Filters on a BX #297
All of a sudden posts seem to be doubling up on their own....?
   / Do your own Fluids and Filters on a BX #298
It happens, there will be a rash of it, and it will quit for a while.. You can delete the extra post, but going back in on one of them to edit, and pressing delete, then delete message, and then the delete button at the bottom. It is 3 button presses, but it makes the extra post go away completely.
   / Do your own Fluids and Filters on a BX #299
Yep, I did just that and it works like a charm...:thumbsup:
Kubota Oil Filter
Appreciate a report back after you change from the Kubota SUDT/SUDT2 hyd fluid as to noticeable change in performance. Also what is the cost of a qt of the engine oil that you are changing to?
Root Rake - 8FT WIDE - Fits Dozers (A56438)
Root Rake - 8FT...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A56438)
2023 Takeuchi TL6R...
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
