Mounted New Tooth Bar
/ Mounted New Tooth Bar #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
Spring is finally coming so I mounted the WR Long Tooth Bar I got last month. Used a 3/4" hole saw that had a 1/4" pilot. Marked and drilled a 1/4" hole from the inside then used the piloted hole saw from the outside.
/ Mounted New Tooth Bar #2
Go go gadget .... bucket :)
Looks aggressive.
/ Mounted New Tooth Bar #3
/ Mounted New Tooth Bar #5
You'll love it. love my tooth bar makes digging in the clay easy. They are also great for stacking extra fire wood in the bucket and grubbing out rocks
What do you have on the leading edge of the sides of the bucket?
Q-Tips - :laughing:
I have to stay right in front of the garage. It is the only dry place. Good thing I have some little jobs like the tooth bar to do. And this computer to waste time on.
Where the grass is bare it is all standing water on top of the frozen ground. You sink in about 3 inches. And this is what the other direction looked like this morning. Oh well. lots of others have it worse.
Some short pieces of 1/2" rebar. Teeth so I can grab a log easier, The tooth bar will there too.
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2023 Global Trailers GT302 60YD T/A End Dump Trailer (A59230)
2023 Global...
Deere 35G (A53317)
Deere 35G (A53317)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
AGT Industrial M-DGR (A60463)
AGT Industrial...
