Bobvt
- Joined
- Oct 13, 2003
- Messages
- 153
- Location
- Westford, Vermont
- Tractor
- Mahindra 6500, Mahindra mPower 85, LS XP8084CPS
Does anyone have any experience with 00 series transmissions? Late last fall, the gears began to grind when I would shift from reverse to forward after the tractor warmed up. (No grinding if come to a complete stop and slowly shift to forward.) They do not grind moving from forward to reverse. I suspect the problem is with the reverser shifting sleave and synchronizer hub. I'm hoping it just the block, spring and ball which slides into the hub. Started yesterday getting it ready to split. I would appreciate any advice that would help in identifying which transmission parts need to be replaced.
