3-Point Hitch log splitter adaption
/ log splitter adaption #1
paul currey
Mt.Clare
kioto lk3054
I am planning to adapt a county line splitter to my kioti lk3054 tractor.what is involved and I understand the support legs on this splitter is inadequate.
/ log splitter adaption #2
I did the opposite, I took a tractor mounted splitter and added a 5hp motor. Running a thirsty tractor to do what a small motor will do was a waste of tractor hrs. and fuel. It's also nice to have the tractor free to move wood, bark, etc.
You didn't ask but, I thought that I might share my experience. I'm sure others may feel differently...Mike
/ log splitter adaption #3
/ log splitter adaption #4
I would be surprised if you had the thru put to run a gas splitter on tractor hydraulics. Tractor is probably putting out 8 or 9 gpm while the gas splitter has a two stage pump running maybe double that gpm. I am sure there are others on here better equipped to answer your question than I, but you should check the gpm required by the gas splitter.
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
Loader Brackets (A65640)
Loader Brackets...
Rol-Air gas powered portable air compressor, Coal Valley, IL (A65640)
Rol-Air gas...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
