I would just add a possible qualifer to Chris's excellent post, above:
The backhoe may require you to add the
subframe kit (to give you the "four point hitch/connection" that the hoe requires)...unless your tractor already has this one it? When you add the backhoe, "Build Your Own" automatically tacks it on to the figure Chris listed, and it's
an additional $984. Still well worth it, but just pointing this out, FYI. And if I'm wrong, and your tractor already has the subframe, please let us know--I'd be surprised if it does.
I would also get the optional, rubber "street shoes," at $248., unless you want to make some of your own, out of old truck tires or whatever. Otherwise, you'll be marking up concrete/macadam, etc..., and I imagine the hoe would skid around on paved surfaces, without them (?).
I also like Woods hoes a lot, but I suspect they might take a different subframe from the Kubota hoe--but I'm not sure. I have talked with an engineer or two, in Wood's technical dept., in the past, so they are accessible.
What I like about the Woods BH80-X "Groundbreaker" (a curved boom unit, like the
BH77, but your BH65 may not be a curved boom?) is that it has an adjustable swing speed control on it. However, last I knew, you could not get the
adjustable swing speed on a Woods hoe smaller than the 80-X, which is an 8-foot hoe and would probably bigger than you'd want, on your
B2620. As of a couple of years ago, the Woods' 80-X was also the smallest Woods hoe that they had engineered an
optional hydraulic thumb for, something that Kubota still doesn't have for the
BH77, AFAIK. If that's important to you, you might see if Woods now offers it on a hoe less than 8'. If you find that they do, again, please share--I'd be interested to know.
Just my .02, from my previous research. YMMV.
Let us know, and good luck!
My Hoe
