Anyone ever had their ROPS top part cut down?
   / Anyone ever had their ROPS top part cut down? #21
Here's a couple pics to support my opinion.
First is my M9540. Second is a SCUT. Note how much taller the ROPS is on the SCUT.
I keep mine folded all the time when my canopy isn't mounted on it, so i guess that tells where i am on this subject, but........ the little green one has a taller ROPS because it is a shorter machine. If it were longer to create an shallower angle , the height would be very close to the orange one. Psst.... I'd like to drive that orange one around for a while :thumbsup:
   / Anyone ever had their ROPS top part cut down? #22
My first tractor didn't even have ROPS. Have you never seen how people totally modify trucks, jeeps cars?
You mean like this???
   / Anyone ever had their ROPS top part cut down? #23
I'm not all that impressed with the ROPs on my tractor. It does fold low enough for the garage. If it didn't I wouldn't bat an eye at the thought of modifying it.
   / Anyone ever had their ROPS top part cut down? #24
Now go measure the distance from the top of the ROPS to the top front of the engine block on each tractor.
Then draw a line from the top front of the Deere's engine block to a point above the seat cushion roughly equal to the height of the Kubota ROPS above its seat. The shorter Deere chassis dictates a higher ROPS to maintain the 'triangle of life" (my term) providing sufficient space to survive a 180 degree rollover. We dealing with engineering parameters here, not a single linear design specification.
As always, whether I convince anyone of anything here on TBN has no effect on the night's sleep I will get tonight.
   / Anyone ever had their ROPS top part cut down? #26
Hey, I'm with ya. I couldn't find a better pic of the SCUT. And my SCUT, JD2210, has the ROPS removed because I got tired of tree limbs smacking me in the head trying to mow under them.....You gotta get in line behind the "quacker" man to get a run at the orange one.
   / Anyone ever had their ROPS top part cut down? #27
Well, that's good.
   / Anyone ever had their ROPS top part cut down? #28
That roll cage can't be safe... It wasn't welded by some guy at tractor company over seas:laughing:
That outfit is what happens when you give your Son a pile of pipe and a good bender. You get a view inside their brains. Scary....
   / Anyone ever had their ROPS top part cut down? #29
   / Anyone ever had their ROPS top part cut down? #30
Now go measure the distance from the top of the ROPS to the top front of the engine block on each tractor. Then draw a line from the top front of the Deere's engine block to a point above the seat cushion roughly equal to the height of the Kubota ROPS above its seat. The shorter Deere chassis dictates a higher ROPS to maintain the 'triangle of life" (my term) providing sufficient space to survive a 180 degree rollover. We dealing with engineering parameters here, not a single linear design specification. As always, whether I convince anyone of anything here on TBN has no effect on the night's sleep I will get tonight.
For me at least,,, this is not an argument at all. It's a learning discussion.With that said, if you think you can find a safe spot to hide in the "triangle of life" on the Kubota in a rollover, you are a lot smaller man than I. I was liberally going from the hood. If I gotta shrink that triangle down to the engine block, there's no survivor, the steering wheel would actually hit the ground.
(22) Assorted Webbing Slings (A57453)
(22) Assorted...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
2001 Dorsey DOTS48 48ft 39 Ton T/A Flatbed Trailer (A56858)
2001 Dorsey DOTS48...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59575)
2017 ISUZU NPR 18...
Bench Grinder (A57454)
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
