Need help figuring out what this motor is......
   / Need help figuring out what this motor is...... #1
mx842
Richmond Va
Kubota L3301, PowerKing 2414, John Deere 316, Gravely ZT HD 52
I've been collecting parts to build a wood processor for a long time. I've come across several motors and pumps that I figured I could use for one part of the build or another. I was at an auction last week and they put up a junk with all sorts of stuff packed in it and at the bottom of the box I saw what looked like a big ol hyd pump or motor and what looked like a great big saw bar. They wouldn't let you dig into the box to see what was inside but I figured what the heck. They started out at $150.00 and no one took the bait so after a bunch of pleading from the fast talking auctioneer they started to close out the box and move on but I yelled out 50 bucks!!! The guys on the stage looked at each other and as one of them scratched his butt with a puzzled look on his face the other guy yelled out SOLD!! to the guy in the second row with the camo hat on.
I turned in my tickets for the stuff I had bought and as I backed up to the door the guy that was loading the stuff told me, MAN you got a deal with that box of stuff there. He said that he had planned on bidding on it but they had called that box while he was in the out house. Anyway he offered me $100 bucks for the box and I may have taken it if he had not already told me how good of a deal I had gotten so I said nawh I'll just take it home with me.
I pulled away but I just had to look inside to see what was in the box so I pulled over to the side and started digging. That same guy came over and said how's about $150 before you go digging? But by then I had already grabbed a hold of that big old 404 bar and under it was the chain to go with it along with the sprocket and a bunch of other related parts. I said sorry but the cat's out of the bag and that I had been looking for this kind of stuff for a long time. He then told me that the parts had come off an old delimber cut off saw that had come loose from the tractor and had gone off the side of the road and down an embankment. He said the insurance company had bought it but never came to pick it up and after several months the storage was more that they wanted to pay so they gave it to the shop owner as scrap.
Anyway long story short they stripped it out and scrapped what was no good and had had the parts on the shelf for several years and finally the old guy died and they were auctioning off what was left. When I got home I found this big saw motor. It's a Parker and there was a tag on it that I could make out PT# 400391. There was some other numbers on the tag but I couldn't make out everything. Also there was a number stamped in the case of the motor that was 3035020002 and another number on the tag that I believe was 303 9310343 There was also 045 stamped in the face of the flange where it bolted up. It is round in shape and has a 2 bolt flange. It's pretty big probably 12" long and about 8" round in size and I can measure it closer if that would do any good.
I have searched all over and none of these numbers comes up anywhere and when I searched the parker site I still didn't see anything that I could say was a match. I think it's a gear pump but I'm not sure.
The saw blade and chain looks like it was just changed out and had very little use on it. The sprocket had some wear but still usable and I believe I could weld up the drive marks and make it like new without much time involved. Looking at it though it would probably last me a lifetime doing the little work it will have to do while I have it.
I'm trying to figure out what kind of motor I would need to drive such a thing as this. That will be the next item I will be trying to run down.
   / Need help figuring out what this motor is...... #2
When I did a search for parker hydraulics PT# 40039, links popped up referring to a f12 hydraulic motor. I dont know if thats is what you have, but if it is you have a very expensive high speed hydraulic motor. These motors are pretty common on forestry havester saws like the item you described. Your best bet is to call Parker and find out a little more about hydraulic requirements for this motor. Depending on just how big a processor you plan on building, this could be a very good saw motor, or a very expensive part that might cost you more to power than what you would want to spend. The 3035020002 number might suggest a F12-30, but here are the part numbers I found for a F12-30's, and your numbers dont match any of these
F12-30-MF-IH-D 3799843
F12-30-MF-IH-K 3799844
F12-30-MS-SH-S 3799851
F12-30-MS-TH-S 3799616
F12-40-MF-IH-D 3799525
F12-40-MF-IH-K 3799526
F12-40-MS-SH-S 3799532
F12-40-MS-SH-T 3799533
F12-40-MS-TH-S 3799617
F12-60-MF-IH-D 3799988
F12-60-MF-IH-K 3799989
F12-60-MS-SH-S 3799998
F12-60-MS-TH-S 3799618
F12-80-MF-IH-D 3780767
F12-80-MF-IH-K 3780772
F12-80-MS-SH-S 3780783
F12-110-MF-IH-D 3781530
F12-110-MF-IH-K 3781534
F12-110-MS-SH-S 3781542
Here is the link I found this information, it might give you a start to figure out what it is you have. http://www.parker.com/literature/Literature Files/hydraulicpump/cat/english/F11-F12_HY17-8249-US.pdf
And to add, it you decide you cant use it, I am interested in purchaseing it
Thanks a million.....I searched for 2 days and never came up with anything, I even moved numbers around in case I wrote something down wrong but I never thought about dropping the last digit. I will look at these links you gave and see if they lead me anywhere. Thanks again.....
Dang!!! I have two computers that I could post a pic from but one needs a mother board before I can get it fired back up and this one is so slow right now because it needs more memory that it wont let me do much more than start it up and peck around on the internet.
I found a motor that is similar on e-bay. This one has a 1" shaft, the one on the motor I have is 11/4". This one has a 4 bolt flange mine has a 2 bolt flange. I can't tell if this one has a fitting in the collar between the flange and the pump body but the one I have has. This fitting was used to oil the chain I believe
Notice the shaft does not come out of the center it is off set the same way as mine. I don't know if that is considered a bent axis motor or not but from what I have looked at on the parker site it looks like the f11 and f12 motors are bent axis motors but nothing I saw there look the same as this motor or the one I have.
Mine has a plug in the side of the frame body just like the one on e-bay, mine also has the work ports in the back of the body just like the one on pictured there. Notice, it has 4 large bolts holding the unit together just like the one I have.
140235 Parts Only Commercial R 697817 10 05 Hydraulic Motor 4 Bolt Mount 1"NP | eBay
   / Need help figuring out what this motor is...... #8
From your link, I can only guess that what you have isnot a f12. I would not let that discourage you from using the motor as a saw motor. You need to find out what you have first before starting the build. While some folks use small cuin motors and run high rpms to power their hydraulic saws. Lots of manufactures will use gear motors in the place of the more expensive F11-f12 parker motors. I dont have the exact numbers in front of me right now so I am just talking off the top of my head, but. A 2cuin motor with 30gpm at 2500psi, will give you a rpms of around 3800rpms and 20-25hp. Couple that motor to a 13tooth 404 sprocket and you can get a chain speed of close to 6000ftmin. This is close to the recommended speed for a 404 chain and about 3 times the hp of a 3120 husquvarna chain saw. A set up such as described will give you a very fast cutting saw for your firewood processor. Problem is it will take about 51 hp to power your saw Engine hp is one reason some folks choose the smaller hyd motors and higher rpms for their saws. In other words, the motor you have might not be for everybody, but is doable if you have the parts to make it work just laying around. Before doing anything, you need to talk directly to Parker and find out what you have. It may be that you need to sell the motor you have and look for one a little easier to adapt for your purpose. I am no longer interested in purchasing the motor as it is not what I hoped it was.
Another problem with your motor is shaft size, it is going to be very hard to find a 1 1/4 bushing for a chain saw sprocket. I think the sprocket without the bushing is less than 1 1/4 bore.
I thought I had corrected the 404 part. It is a 3/4 drive setup. I have the bushings and the gear drive. The one that they were running was a 9 tooth sprocket. After looking at them they are not in as good a shape as I thought but they don't look all that hard to make if I can access someone with a CNC plasma cutter. I know several people that have them so maybe I could work something out.
I called Parker and they transferred me to someone else and I left a message. Hopefully they will call me back.
Well I finally got in touch with Parker. I don't know what happened the first time I called but I went the e-mail route and a nice fellow got in touch with me and sent me some information on the motor I have. This is a motor that was made by a company that Parker bought a few years ago. The company was Commercial intertech.
I gave him the 303 9310 343 number and he came right back and said it's a 25X, fixed displacement motor with a 11/2 inch gear. Evidently these motors were widely use as saw motors in the 90's because the first thing he asked was,........was it on a piece of forestry equipment and used as a saw motor? When I told him yes he told me that these were use by most of the equipment manufacturing companies back then and probably why Parker bought the company so they could sell more of their F series saw units.
Anyway he sent me some information on the motor, now I just have to figure out what it all means. This is a link to a pdf file with the information on the motor. Hopefully someone can help me figure out what this all means but just me looking at it, it looks like I will need more HP than I have right now on hand.
http://bbhydraulics.com/products/docs/commercialparker/p25x.pdf
   / Need help figuring out what this motor is...... #11
You could run it from a dedicated pump at lower pressure to get the speed you want and transmit all of the power you have available.
I'm not sure I follow you. But running more than one pump on this processor is not something I really wanted to do. If I have to wait until I come across a larger engine then I'll just have to wait for awhile longer. I'm still looking for a pump and a valve to run this thing and just wanted to weed out stuff that is to small for the job. I was thinking about running part of the unit, log clamp, splitter, wedge adjustor and possibly the saw blade cylinder from a three or four lever hydraulic valve and the saw motor, out feed conveyor motor, and probably the live deck by electric solenoid valves.
I've been trying to figure out how to incorporate the log clamp, saw motor, and blade control cylinder sequenced together all by one electric control but I'm still having trouble getting my brain to filter all that out.
If I have to run more than one pump I guess that wouldn't be to hard to configure into the system but I still don't get why I would need to do so. The saw motor will only be pulling power a small part of the time much like the majority of the different parts of the unit. Hopefully you can elaborate a little more on this point of thought. Thanks for your reply.
   / Need help figuring out what this motor is...... #13
What I think he alluding to is that if you try and run everything off of one pump, each item you activate will take a certain amount of fluid.
If you want a constant flow, you will have to use a priority divider circuit, or several pumps.
If you are try to do multiple things at once, your timing may be off on critical things.
An engine can drive multiple pumps, like one feeding the saw motor, and the other the splitter, log lift, conveyor, etc.
GPM's determines the speed of operation, so if one component takes half of the fluid, the other component will slow down, etc.
You probably want max speed on the splitter cyl and the saw.
Thanks JJ, I was thinking that is what he meant but just wasn't sure. What is the best way to run multiple pumps off a single engine? I would assume you would have to run them off belts and pulleys??
   / Need help figuring out what this motor is...... #15
No, some of the grounds keepers machine, use three or four pumps piggybacked on a single shaft.
Surplus Center
A pumps flow and pressure will dictate the HP required to drive it to full capacity.
Surplus Center
Silly me, I had been looking at multiple pumps and motors for days while searching for info on this big motor I have. It just never registered what I was looking at when I was looking at them.:duh:
I get cornfused when I start looking at the graphs and charts about input/output/gpm's@ this or that RPM of a pump as it equates to what the effects are on a motor, pressure??? gpm..... torque, speed it will turn a load. I guess the question I need to ask is if I have a 62.7 hydraulic motor designed to run @ 2000 rpm's what size pump will I need to hook up to it to get the full RPM potential and how do I turn those 2000 RPM's into the 5500 to 6000 feet per minute or what ever it is, needed to drive that 3/4 drive chain. Is there a chart somewhere to figure all that out?
   / Need help figuring out what this motor is...... #17
62.7 cu in is a rather large motor, and if you gave it 20 GPM, it would run at 74 rpm.
A 10 to 1 ratio would turn a shaft at 740 rpm.
To get 2000 rpm out of a motor that large, you would need about 550 GPM's.
The motor will run given about any GPM.
Motor torque would be about 24,881 in lbs, at 2500 psi.
I could visualize you using about 20 GPM for the log splitter.
------------------------------------5---------------hyd chain saw.
------------------------------------3---------------log lift.
------------------------------------3---------------log pusher.
------------------------------------3---------------for conveyer.
Maybe more, maybe less if using a pump for multiple things.
A pump or pumps needed to produce 34 GPM's using engine speed of 3600 rpm would have a displacement of 2.2 cu in.
HP required would be about 58.
If you need some help , go to the technical help here. Surplus Center
Use the hyd calculators in the left panel.
Surplus Center
   / Need help figuring out what this motor is...... #18
This 2.31 cu in pump will produce about 34 GPM's at 3600 rpm and has a psi rating of 3000.
2.31 cu in PRINCE HYD PUMP SP25A38A9H2R
You would have to divide the output for different operations.
A tandem pump would be preferred for different flow rates.
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
HYDREMA 912HM ARTICULATING WATER TRUCK (A60429)
HYDREMA 912HM...
