Diy compact tractor
/ Diy compact tractor #21
:thumbsup:
Rear axle finished and propshaft made
Starting to look like something
I have managed to get out to the garage and get the drivetrain finished, just a tensioner and clutch pedal to sort out. Having ran the engine to check get rartios I am quite happy with the mix of low grunt in 1st (10 rpm at 1000rpm!) and reasonable pace in top with the revs up (didn't time it was too busy holding the tractor, stopping it falling off the axle stands!)
/ Diy compact tractor #26
Gotta love that big old flywheel !
Good progress, at this rate you'll be putting your garden in with it soon !
Word of advice - I'd strongly suggest posting a video of it running when you are done..... otherwise, you might end up with a whole pile of TBN'ers camped at the end of your driveway, trying to get a look ! :laughing:
Rgds, D.
Agreed! I def would like to post several videos, never had much success however with YouTube, once it's running proper I will have to consult someone! Oh you need a big flywheel when you can hear (and see) the individual combustion events! It's only 7 1/2 hp but takes a bit of stopping this little British engine!
/ Diy compact tractor #28
Chaffe, I admire your building skills and work. Thanks for posting your project
/ Diy compact tractor #31
Landie rear axle and transmission, and an old field milking parlour engine ? My father ran one similar 40 years ago, a Wolseley just with an open top egg cooker cooling system :)
Hi, landrover rear axle, however the gearbox is from a Volvo, the engine is one of the more modern lister-petters from the late 1980's to present day, it has good power and revs quite high (upto 3000 rpm) however I do have another much heavier lister LR1 that only revs to 750 and makes a mere 1.5 hp forever!
/ Diy compact tractor #33
Interesting, I didn't realize the later ones rev'd that high. Is that a factory redline, or unofficial ?
Rgds, D.
Rgds, D.
Standard specification for this engine, still available new now.
LT1
/ Diy compact tractor #35
LT1
Good example of why I hang around here.... always something to learn !
Thanks Chaffe.
Rgds, D.
Thanks Chaffe.
Rgds, D.
No worries! Not sure it would be a pretty sight at 8bhp! Be a lot of smoke involved!
/ Diy compact tractor #37
Very interesting project.You seem to be doing it at a good pace.I am very interested in seeing the finished product,good luck with it.
Thanks for the support, it should be getting done much quicker but I'm only managing an hour here and there, a full time job and seven month old baby take priority!
Another hour spent on it tonight, re made some of the clutch parts, much happier now!
No idea mate, I'm no lister expert. This one is ideal for my needs though
PAIR OF DIAMOND PLATE DBL AXLE FENDERS (A62130)
PAIR OF DIAMOND...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
2014 Infiniti QX60 SUV (A61569)
2014 Infiniti QX60...
2018 Regal 29OBX 29ft Boat with 34ft T/A Boat Trailer (A61569)
2018 Regal 29OBX...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
