Dirt Moving Should a box blade float?
/ Should a box blade float? #1
Dave Riebau
Kubota L3800
I just bought a box blade and I tried it out in a gravel driveway. I basically leveled it side to side on the 3 point, Kubota L3800, 6' blade, not using the rippers, and it really digs in. I was hoping to level with it, rather than move the gravel. Should I not completely lower the 3 point so it doesn't float? Snow set in, so I can't use it now anyhow as I was just playing with it but thought I'd get your opinions. I did try tilting it back, but it still digs about the same. Thanks.
/ Should a box blade float? #2
The length of the top link is what will set the depth of the cut.... the longer the top link the more cut, shorten it up and it will cut less... You will normally set it up for the job you are doing using the top link and allow it to 'float' ... KennyV
/ Should a box blade float? #3
Does your box blade have a solid or hinged rear blade?
Adjustments are different as the top link extends.
Bruce
/ Should a box blade float? #5
leveling gravel is tough with a box. it becomes something of a manual process and needs user input to keep the box from doing just what you're experiencing. i usually float but find myself adjusting quite a bit as i go along.
if it's an option, you'd probably be better served by a land plane/leveler. tearing up the surface with scarifers (on the leveler or with your box) and then following up with the planer makes for good results. for extra-fine results (i.e. baseball diamonds or horse rings) you can make a final pass with a drag harrow
/ Should a box blade float? #6
If you have a double edged box blade, that is, one that has a cutting edge when going forward and a cutting edge when going backwards like this )( ,then you can lengthen the top link until the blade on the back side runs on the ground. The front edge of the forward blade will not be touching the ground.
That will greatly reduce any tendency to cut while going forward. It is a great setting for smoothing in float.
Then you can shorten the top link a half-turn at a time until it is set perfectly to just skim the ground in float. It doesn't take much shortening to radically change the cut.
/ Should a box blade float? #7
Should I not completely lower the 3 point so it doesn't float? .
Your 3pt should float at any height. There is nothing that prevents it from floating up, you just set the depth by how high (or low) you raise (or lower) it. You adjust the aggressiveness of the cut via the top link. Play around with it till you get your desired results. A hydraulic top link helps a ton here and makes the trial and error process much more enjoyable. What kind of box blade do you have, how much does it weigh. The heavier the better to control your desired output.
/ Should a box blade float? #8
The box blade on gravel is not a drop and go implement. You are going to have to go slow and work the 3PH up and down yourself. KennyV and gwdixon gave you good advice on adjusting the toplink.
What are you trying to do with your box blade on your driveway? Do you have any other grading implements?
/ Should a box blade float? #9
You do want to use it in float when smoothing a driveway. If it has dual cutting edges (one forward, one reverse) then lengthen your top link so that the front edge is not biting and the rear edge is feathering. That is a great way to smooth material. From there, gently shorten the link if you find you need more bite from the front edge (which will fill the box with more material).
The whole trick with a box blade is that once you get the cutting edge set where it should be, the box will remove material from high spots and redistribute to low spots. It works amazingly well at this. Practice until you get it perfect.
/ Should a box blade float? #10
Landpride makes a grading scraper like the yellow one pictured above that also has 5 scarifiers on it as well. I love mine and it weighs around 550 lbs. I leave it on most of the time for rear ballast.
/ Should a box blade float? #11
If you shorten the toplink the front edge of the sideplates will contact and limit the amount of bite the cutting edge can have. The side plates will float the blade. I bought and hydraulic toplink with mine definitely worth it
/ Should a box blade float? #12
I've had similar issues with my setup and have considered adding a set of skis to my boxblade to allow it to "float" instead of just dig in.
/ Should a box blade float? #13
I have the EA Land leveler for the L3800. Previously I spent hours and hours on my 1000' driveway. Fun for awhile, but it had to stop and that's why I got the Land leveler. Glad I have it as it really speeds up the driveway grooming process. Still I wish I had known about adjusting my little BX sized boxblade. Got to try out the top link adjusting when things dry up. :)
/ Should a box blade float? #14
Ha, ha! You must have missed post #6. But your post confirms it for the OP.
/ Should a box blade float? #15
I'm curious as to how you propose to not use the "float" on 99% of tractors that have been built???? Very few tractors that have a 3 pt that doesn't freely float IE no down pressure except for the weight of draft arms & attached implement!!!
/ Should a box blade float? #16
When I put a hydraulic Top 'N Tilt on my Kubota, the box blade became very easy to use effectively. Before that it was a slow process for me because I'd have to keep adjusting the length of the top link manually.
/ Should a box blade float? #17
Yes, I undertand what you mean. Let's redefine my wording to say drop the hitch all the way so the box will almost always be in floating contact with the road surface.
I have seen/read plenty people here who grade with their box off the ground a bit, for whatever reason. In that case it's in "hover" much of the time unless they run into a high spot!
/ Should a box blade float? #18
Welcome to TBN, Dave! :welcome:
At least with the double-edged type box blade )(, this is exactly backwards - lengthening the top link will tilt the box blade toward the back so that the rear blade sorta skims/floats/smooths the surface without cutting, and the cutting edge of the front blade is tilted up so that it doesn't contact and cut the surface. Shortening the top link will tilt the blade towards the front, which will cause the front blade to cut in and may dig in to some extent on soft surfaces. It is true that when the blade is tilted forward (shorter top link), the side plates will to some extent keep the front cutting edge from digging in too much, but my blade is heavy enough that the relatively thin side plates easily furrow themselves down into the surface so that there is not much "lift" that they provide.
- Jay
/ Should a box blade float? #19
OK, maybe a dumb noob question but I'm curious, as I have a LP BB, but am thinking I'm going to need a grader also; Can the front blade on the BB be taken off, or even turned around for smoothing/grading? Might be a pain I know, but might also be a solution for those who don't (Yet), have the grader.
/ Should a box blade float? #20
If you have dual cutting edges, lengthening the top link will effectively get the front cutter off the ground so that the rear cutter feathers and smoothes. See above posts. No need to remove the front cutter at all.
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
New/Unused Wolverine 66in Quick Attach Rock Bucket (A65583)
New/Unused...
3'6"x5'6" Aluminum pickup Roller Tray (A62679)
3'6"x5'6" Aluminum...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
