TC 33 Squeaky jerky hydraulics
   / TC 33 Squeaky jerky hydraulics #1
Billy Bee
Lowell Michigan
New Holland TC 33, John Deere 3020
This winter when it was really cold my hydraulics started getting real slow and jerky. Then 2 times when it was cold they wouldn't work at all. I read posts on TBN about water in the fluid, figured that was the problem. It finally got warm enough and I changed the fluid and the filter. this is a gear model so only one filter. The hydraulics work, but they are squeaky and jerky on the loader and the 3 pt. The squeaking seems to be coming from right under the joystick. I worked the loader and 3 pt several times, thought that might bleed the system if it needed it. Also the loader squeaks more going up and curling back. Is there something else that needs cleaning? I bought this tractor used and it worked fine until the weather got cold. It makes the same sound when I work the 3 pt.
Thanks in advance for your help.
Bill
   / TC 33 Squeaky jerky hydraulics #2
Can you determine if the sound is from the relief valve?
If you use two different valves and the sound is the same, and if the loader is first valve, the relief could be the cause.
If the relief valve is squealing, there is a reason. Could be cold fluid. Something is blocking the flow.
I ran the loader and the 3 pt to the max to activate the relief valve and it is a totally different sound. The sound I hear when using either hydraulic is not a high pitched squeal but more like a groan. Pump? is there a screen somewhere?
   / TC 33 Squeaky jerky hydraulics #4
Some tanks have a screen. If so, remove, check, clean.
That groan could be a cavitation sound where the pump is starving for fluid.
I will look for a screen and clean it. Thanks J.J.
I have the service/repair manual for this tractor with exploded views of everything and there is no screens shown anywhere. Could there be a blockage in the suction tube or is it possible it is getting foreign air from somewhere?
Tx Bill
2019 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2019 Ford F-550...
BEFCO DISC MOWER (A52708)
BEFCO DISC MOWER...
2009 Ford Crown Victoria Sedan (A56859)
2009 Ford Crown...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
TREE PLANTER (A52708)
Clemco 2020 Portable Sand Blasting Machine (A55973)
Clemco 2020...
