Adding remotes to L3830?
/ Adding remotes to L3830? #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello, I have a Kubota L3830. It has no remotes on it. Does anyone know if it's still possible to add the factory remote kit to it? I'm thinking I would like at least 2 remotes.
Guess I need to speak with the dealer but was curious if any of you have done something similar. And especially curious about cost!
/ Adding remotes to L3830? #2
You can probably get the factory remotes, but would you like to do it yourself and save about 1/2 to a 1/3.
If you can round up all the parts, and turn a wrench, it is a doable job, and you can be proud of your work.
How will you use the remotes?
T-N-T or general hyd attachments.
I would recommend at least one spool with float.
/ Adding remotes to L3830? #3
I put them on my 3130 and it was real easy. You well need help to take the seat off, it's heavy. Here is something that may help you make up your mind. You can see where they get the oil from and where it goes back. You can use that even if you build up some.
  • Kubota Remote Hyd valve instruction manual. L3130 to L5030.pdf
/ Adding remotes to L3830? #4
The factory remotes are nice and beats spaghetti hanging from the fender or the ROPS.
Need to talk to the salesman, not parts, as they are kits on the Whole Goods price list.
The base kit has the inner and outer plates and block that bolts to the hydraulics, then each position has a lever and hose kit and then you need to select the type of valve for regular or with float.
David Kb7uns
David Kb7uns
Yes I want it to be factory. Thank you for the replies!
