1986 Belarus 250AS want move.
   / 1986 Belarus 250AS want move. #1
lawandorder39
Callahan, Fl 32011
John Deere 4710
Hello all, just got tractor out of shop having new clutch and pressure plate installed. I started spreading 18 yds of dirt with Belarus tractor loader. After turning tractor off a spell taking a break I started it back up put in gear and nothing happen in forward or reverse.
Does anyone have and idea of what the problem could be?
   / 1986 Belarus 250AS want move. #2
Could the hi-low be in neutral? That's a separate neutral from the regular shift pattern neutral.
No it's shift in drive or reverse and still want move. The PTO operates fine also.
   / 1986 Belarus 250AS want move. #4
G'day I would talk to the guy's that fitted the clutch and see if they can help
Jon
   / 1986 Belarus 250AS want move. #5
I'm not talking about the forward-reverse shifter. I mean if you move the main shifter all the way forward, you push right for low range, left for high range, and center for neutral. If that gear is in neutral it will not move even if you put the same lever in gear in the lower part of the pattern.
http://youtu.be/4Bgp2CoG-fM
   / 1986 Belarus 250AS want move. #6
O god how I don't miss the 250 I had around for a while . Lol way to may levers . Lol
But I would be talking to the guy that done the clutch if it was me .
Sent from my iPhone 5 using TractorByNetlathe
   / 1986 Belarus 250AS want move. #7
I think brad has it.... gear range is in N
1041 (A50459)
1041 (A50459)
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
KLEIN TOOLBOX (A50854)
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
New Holland B95 Backhoe (A50490)
New Holland B95...
