takeflight
Hi wonder if anyone can advise me, you should know I am a complete newby to tractors. Last year I acquired a mf35 four cylinder diesel, bit smokey but it hadn't run for three years, put away last October. Due to the wet conditions, I didn't start it until this week, started up but I now have no clutch, tried adjustment by loosening the pedal and turning the shaft to the right, there's pressure on the pedal but the clutch does not engage. The pto works.
I am sure I have read somewhere there is plate underneath that you can remove and spray under pressure some sort of release fluid. Am I dreaming this and there's nothing for it but to split the tractor.
Thanks
Roy
Thanks
Roy
