Loader Don't let this happen to you.
   / Don't let this happen to you.
Was this the same dealer that sold it to your FIL with the wrong loader on it?
If so, hopefully, they will try to somehow take some of the sting out of this whole situation:)
No, different dealer. I don't think either of us will be doing any trading with the dealer he purchased it from.
   / Don't let this happen to you. #62
I have enjoyed reading through this old thread, and was really happy you got the holes fixed and useable. Then, I keep reading and see this happened. Wow! I love tractors, and I hate to ever see any of them damaged. I really hope something good comes back in the report from the dealer for you guys.
I didn't see it mentioned in any post- did you guys ever design some sort of angle bracket for each side to take the stress off the 4 mounting bolts?
The dealer called and said he had the tractor split, so we paid a visit Saturday. The service manager was not there, but we got a look at the tractor.
It is not as bad as we first thought.
The loader mounting brackets bolt to the hogshead. That appears to be the only broken casting (first picture). I thought the transmission case was broken, but it is only the hogshead.
The front drive shaft suffered collateral damage and I'm sure other parts will need replacing, like possibly the clutch and pressure plate, but most of what we saw appears to have gotten by unscathed.
The plan now is to repair the tractor and purchase a loader made for an L4310. I doubt being able to find an LA682 Kubota, so it will probably be an aftermarket ...possibly a Woods?
Anyone in need of a good used LB552 loader?
IMG_20140322_110529_054.jpg IMG_20140322_110557_258.jpg IMG_20140322_110543_068.jpg IMG_20140322_110259_827.jpg IMG_20140322_101552_449.jpg
   / Don't let this happen to you. #64
Never even thought of checking mine but I got a 1/2" Milwaukee 18v impact wrench for Christmas so I went around checking everything. Nothing was loose but it's probably wise to check them every so often.
I know this is a reply to an old comment, but I feel the need to make it.
Frankly I wouldn't let you near a single piece of my equipment, be it a car, truck, bus, tractor or the dead MTD in my side yard.
Back in the 90's I had a flat on my Monte Carlo in the morning. Full size spare in the trunk and a warranty on the tire. So it was going to be a matter of taking off the flat and running it up to the tire place five miles away. I'm over 200 pounds bouncing on the lug nuts to get them off. They didn't f***ing budge so then I try PB Break Free overnight and try the next day. No luck.
I even got to the point of trying to chisel one of the lug nuts loose and had no luck.
So on the third day I finally went the Fix-A-Flat route and drove it up to the shop. The tech talked to me and said essentially that he didn't believe they were on that tight. He took a wrench out and tried the bad tire and the other four and couldn't break a single one loose by hand. They replaced the tire and repaired all the damage I had done to the lug for free.
A side note that the state of Ohio passed a law in between the time I got the tires and needed the repair. All lug nuts need to torqued and not done with an impact wrench.
So anybody who thinks an impact wrench is the answer is just as bad as the owner of a hammer in my view. :2cents:
The dealer found a NOS LA682 loader. There are actually two of them available in the US; well, one now. Kubota recommended a different valve assembly, not sure why unless the flow rate is different, but the bucket on the LB552 will work on the LA682.
   / Don't let this happen to you. #66
A few years back I had that problem with the wheels on a Forester. I managed to shear off three lug bolts (two on one and one on another) trying to get the tires changed over. I never thought a wimpy guy like me could exert that much force with a simple T lug wrench.
   / Don't let this happen to you. #67
That's funny and obvious you don't (yet) have a quality impact wrench.
By the way, laws on wheel torque are to ensure they are tight enough to stay tight, not loose enough to easily remove. I've had lugs loosen and ruin a $300 wheel center and 8 wheel studs. So, I'd rather spin them down hard. Just my opinion.
   / Don't let this happen to you. #68
To each his own.....A friend bought a new pickup truck, took it to tire shop to have them install new aluminum wheels. They broke 5 lug bolts and he had to have a machine shop remove the rest of them and press in new lug bolts.
I bought a car and had to use an 8 foot cheater pipe to break the lug nuts loose. They popped like a shotgun, but I did get them loose. After that, I tighten to 80psi using 4 way & torque wrench. Never a problem getting them off after that, even for wife using 4 way.
I NEVER use an impact wrench to tighten.
   / Don't let this happen to you. #69
Wheel net torque can vary greatly from vehicle to vehicle. Some are as low as 65ftlb and some are as high as 350ftlb on some light duty trucks.. You need to follow the manufacturers spec and use a quality torque wrench. If you are using an impact you don't have an idea how tight they are.
   / Don't let this happen to you. #70
...... If you are using an impact you don't have an idea how tight they are.
Maybe in some cases, but not universally true. When my dad ran a tire shop all wheels were reinstalled with an air-powered torque wrench with only an occasional check with a torque wrench. The shop air pressure was always the same within a narrow range. IR wrenches and CP wrenches did result in different torques, but operators that used them every single day quickly developed a feel for proper torque with each individual wrench and I would wager that final torques on any and all vehicles were within 5 ftlb of the correct values. Of course, one needed to be mindful of the wheel stud diameter and adjust the "feel" accordingly.
- Jay
John Deere 3025E (A53317)
John Deere 3025E...
2006 APPA TL (A55788)
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Online Buyers Premium (A55272)
Online Buyers...
2019 International HX620 T/A Wet Kit Day Cab Truck Tractor (A55973)
2019 International...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
