kubota m7040
/ kubota m7040 #1
omondi
nairobi, kenya
m7040
the tractor raises its lift arms without load but with the disc cant raise unless u accelerate the tractor. what might be the problem?
/ kubota m7040 #2
Could be the flow adjustment valve under the seat needs to be turned up to increase lift capacity and speed.
Charlie
/ kubota m7040 #3
Could be the flow adjustment valve under the seat needs to be turned up to increase lift capacity and speed.Charlie
Flow control valve limits the speed 3 pt drops but has nothing to do with speed of raising. Valve is also known as "rate of drop" screw
/ kubota m7040 #4
How long since hyd filters were changed? I suggest to get a 3000 psi gauge and plug in breakaway coupler on rear of tractor to check pressure. Surplus Center has a 3000# gauge.
/ kubota m7040 #5
The descent valve will also stop all flow from the cyl, locking it in place assuming good seals.
If your piston seals are leaking, The 3pt might not raise anything.
Like Jim said, plug in a gage and check pressure with the lift lever at max height.
Check your loader first to see if the pump can make pressure.
If no valve operation will show any pressure, suspect the pump.
Your 3pt relief could be stuck open also.
/ kubota m7040 #6
J_J
Correct me if I wrong but if 3 pt relief valve was stuck open then 3 pt wouldn't raise even with no load.
/ kubota m7040 #7
J_J
Little bit debris, little bypass.
If stuck full open, then full relief, no lift.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
RIDGID AIR COMPRESSOR (A65643)
RIDGID AIR...
Prime 283 (A64126)
Prime 283 (A64126)
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
