Need help determining Ford model/year
/ Need help determining Ford model/year #1
dandou
Southington
ford/5550
Hello,
I bought Ford backhoe/loader. I was told it was 1981 5550. I need to identify model/year to order parts. The cab states it is a 7500, the loader decal is 5550, but it has been repainted and may be pieced together. 4 cyl diesel, no turbo.
The starter plate numbers:
J511J - Tractor Model No.
2J12B - Unit Date Code
*C352171 - Serial Number
Thank you!
/ Need help determining Ford model/year #2
First off, welcome!
The 7500 was turbocharged...so it's probably not a 7500 (engine swap is possible, or some variation of removing the turbo and using a 5550 induction setup), or they did an engine swap. The 4550 had a 3cy engine, so that should be ruled out.
First off, welcome!
Yes, no turbo and a 4 cyl. Looks a lot like 755 and the instruments are same type as 7500 long line of gauges. It is also tall and heavy as the 7500 and 750...
/ Need help determining Ford model/year #4
what's stamped onthe bellhousing aft of the starter? and does it match the foil tag under the hood?
There is no foil tag under hood.
This is by the starter:
J511J Tractor Model No.
2J12B Unit Date Code
*C352171 Serial Number
/ Need help determining Ford model/year #6
date codes run 10 yr ranges, thus a 2 is a decade ending based on the actual model. I'm not as up to date past the x000 or x600 however.. the 2 in your date code.. if it is an 80's decade range would be 82 and J is september 12 is day of the month B is day shift.
( now if it was a 70's range.. that would be sept 12 1972 etc. )
now. I don't know about ford re-using sn's.. but a sn of c ( a us # ) 352171 fals in the early 70's range... in 72 to be exact
1972 C327200
1973 C367300
My GUESS is you have a 72 machine.. not 82..
I'm at work with no manuals near me.. so i can't lookup your J model ID code.
Someone like RickB or Ultradog will be able to answer better. they deal with them newer machines much more than I do. I'm stuck int he glory days of the 53-64 4 cyl's mostly... ;)
/ Need help determining Ford model/year #7
if I remember right the 5550 had shifters on the column and the floor, the 7500 was all on the column
5550 had a round hydraulic filter on side of grille with screw off lid, 7500 filter housing came apart in the middle with four bolts
also the 5550 was built from 1/70-12/73 and the 7500 3/73-10/75
both were big heavy massive 17' hoe machines, parts may be an issue and pricey, machines were not built in high numbers
Shifters are on the floor and on the column, I'll check how the filter comes apart, but it sounds like it is 5550.
Thank you.
2023 Bobcat T76 (A64126)
2023 Bobcat T76...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
211299 (A62131)
211299 (A62131)
2020 Takeuchi TB250-2 Mini Excavator (A62613)
2020 Takeuchi...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
