LA243 vs. LA243A and Quick Atach
/ LA243 vs. LA243A and Quick Atach #21
Vanb did you still use your original loader bucket? I thought i read somewhere that you move the pins to the bucket or the kit comes with pins. Either way, my dealer is telling me I will need a totally new different bucket? That doesnt sound right.
/ LA243 vs. LA243A and Quick Atach #22
I bought the Kubota FEL quick attach in Feb for my 3 yr old BX25. No problem using my existing bucket. The kit does come with two center pins and the two outside pins. The outside pins move with each attachment you put on, but each attachment needs a dedicated center pin. You drive up and use the center "hook" on the QA to hook and pick up each attachment, then slide in the outer pins and retaining pins. The QA fit fine with my FEL, though I have to fuss just a bit with the left side outer pin to get it to line up. After 3 years of use, maybe I've tweaked the bucket a little somehow. Still it works fine and works with the older BX25 and BX24 loaders.
/ LA243 vs. LA243A and Quick Atach #23
Just for more reference....while at the dealer recently I asked about adding the QA and he read me an exerpt from his pricing sheet how the newer loader model L243A had the extra gussets and reinforcements that the LA243 did not, hence the "A" on the model #.
Obvioulsy just an engineering change that someone deemed necessary but I hope it works well for anyone with older units. It would be nice if someone had pics to identify the extra reinforcements between the two models.
/ LA243 vs. LA243A and Quick Atach #24
not rocket science. teh 243A has some extra beef for the QA. I am sure using it on a 243 would not be an issue. Engineering runs deep at Kubota, they account for every little change.
/ LA243 vs. LA243A and Quick Atach #25
I have a bx2350 (2006) and the original bucket works just fine with the QA. I moved a lot do class 5 and 300lb boulders last season, no problems. If you want one,go for it they work great.
/ LA243 vs. LA243A and Quick Atach #26
I emailed Jery and he does sell movable forks in addition to the fixed forks, he was just out of them when I questioned him. I am not sure of the weight or cost of the movable forks of Jery's but I would love to know, I just don't want to keep asking him many questions. I am 99% sure the QA fits all the BX models with no issues weather its Kubota's, Jery's or AI2's. I will say I like Jery's the most but yes it is more then twice as much money.
/ LA243 vs. LA243A and Quick Atach #27
Jery told me my Tach-N-Go will not go on a newer BX machine. My tractor is the BX2230, with the LA211 loader, welded straight arms not the curved arms. Jon
/ LA243 vs. LA243A and Quick Atach #29
You mean it won't go on OLDER machine. I've got his QA on my BX2670, and had it on my BX2660.
You have to tell Jery which loader you have. My Tach-N-Go does not fit your machine, being yours is newer. (If I understand what Jery told me.) Jon
2000 Peterbilt 378 Tri-Axle Dump Truck (A59230)
2000 Peterbilt 378...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2011 Chevrolet Cruze Sedan (A59231)
2011 Chevrolet...
2008 CAT D4K XL (A58214)
2008 CAT D4K XL...
Zero Turn Mower (A59231)
Zero Turn Mower...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
