New B3030 owner in need of instructions...
   / New B3030 owner in need of instructions...
I took some shots of my manual. This will get you started: it's about starting your tractor.
I never start my B3030 in neutral or with the parking brake on. You can start it in gear. I like medium range for most things.
Thank you very much! I realy appreciate this! Very helpfull! :thumbsup:
Kind regards,
Edward
   / New B3030 owner in need of instructions... #12
Flyfish,
I would caution you about one other thing. Never force the shifter for the 2wheel drive to 4wheel drive or the shifter for the 3 different speed ranges. If the shifter doesn't want to go between 2wheel to 4wheel smoothly, then drive the tractor forward a little or reverse it a little, then retry. For the range slector, sometimes it is best to throttle down then try to move the range slector. Sometimes it is easier to go to N, then to the range you want. Never force anything.
   / New B3030 owner in need of instructions... #13
Flyfish,
Took two other pics to make your head spin further.
Edward, to start the tractor in the cold, assuming it is cold in Norway now, you turn the key til the little coil on the dash lights up and you hold the key for 5-10 seconds to heat the glow plugs. Then turn the key the whole way to start the tractor, let it idle for a minute or two to let the engine/oils warm up a little. Longer wouldn't hurt either. Make sure the emergency brake is off by pushing the brake pedals to release the orange lever just below the steering wheel on your right.
Your gear lever on the left has L, M, H. L for very low speeds, (L=loader work), M for slightly faster (such as cutting the grass, m=mower), H for higher speed to get from one place to the other. Practice, practice, practice, go slow. It would take me forever to give you the whole manual (not in front of me just going by memory) but if you have specific questions on something go ahead and ask.
Are there any local dealers that you can contact to obtain a manual?
Love the front hitch, we don't have them in the states here, good looking tractor too. Stanley
Thank you for your instructions Stanley. It will certainly help me.
There is an Kubota distributor in Norway which I will contact and ask if they can provide me a user manual. If not I wil contact Kubota in France or buy a manual on ebay.
Temperatures are not so cold here at the moment. Just around 0˚C. We have had a very mild winter so far but temperatures can drop to -35/-40 ˚C occasionally.
I'm planning to use the front hitch for a snowblower and a brush. Why don't you have those in the States? Is it not allowed?
Kind regards,
Edward
   / New B3030 owner in need of instructions... #16
Kind regards,
Edward
Edward, I should have rephrased that, I've never seen a front hitch like yours on a B3030. They are pretty rare here. Glad members here on TBN can help you, a lot of great folks. Stanley
Hello!
I would like to thank every body helping me with how to get started with the Kuboto B3030. The tractor has arrived today and I have reached my garage without problem. What a nice machine. I certainly will have a lot of fun with it!
Kind regards,
Edward
   / New B3030 owner in need of instructions... #18
Glad you got it home. Keep the shinie side up and the dirty side down.
Hello!
I just received an Operators Manual (PDF file) foro the Kubota B1830, B2230, B2530 and B3030. Is somebody here collecting OM's for later requests? Willing to share... ;-)
Is it possible to upload a PDF file in this forum? If so, what is the max file size?
Kind regads,
Edward
   / New B3030 owner in need of instructions... #20
Glad to see you got what you needed and a nice tractor too boot!
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
Ryobi Gas Pressure Washer (A57454)
Ryobi Gas Pressure...
New/Unused Mini Skid Steer Bucket Mixer (A57454)
New/Unused Mini...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
