John Deere 1020 with poor hydraulic pressure
   / John Deere 1020 with poor hydraulic pressure #1
snowman69
Rathdrum, Idaho
john deere 1020
The high pressure pump looks like it has two inlet lines. I want to check the pressure coming to it. I think the pump in the back of the tractor is weak as it takes a little bit for pressure to build and it drops or looses pressure when using my bucket.
   / John Deere 1020 with poor hydraulic pressure #2
Hi...
Please help me.... Tractor modell - JD 1020 (year 1975).... How I do start the PTO.... The clutch not responding....
If you want, I can send video...............................
The 1020 JD tractor (new) owner, from Europe...........
   / John Deere 1020 with poor hydraulic pressure #3
How long since hyd filter was changed & sump screen checked/cleaned??
   / John Deere 1020 with poor hydraulic pressure #4
Hi...
Does your tractor have a lever between the 2 gear shift levers?
Hi...
On my tractor it is on the left side under the front on the seat. It moves forward to engage. There was some changes between our model years. If not I can find out where it is.
   / John Deere 1020 with poor hydraulic pressure #7
The pto clutch may be stuck if your tractor has the dual stage type pto clutch. The photo shows the pto control lever you refereed to.
2017 Kia Sorento SUV (A55758)
2017 Kia Sorento...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2010 Komatsu WA320-6 Articulated Wheel Loader (A55787)
2010 Komatsu...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
flooring (A55758)
flooring (A55758)
