John Deere 1020 with poor hydraulic pressure
   / John Deere 1020 with poor hydraulic pressure #1
snowman69
Rathdrum, Idaho
john deere 1020
The high pressure pump looks like it has two inlet lines. I want to check the pressure coming to it. I think the pump in the back of the tractor is weak as it takes a little bit for pressure to build and it drops or looses pressure when using my bucket.
   / John Deere 1020 with poor hydraulic pressure #2
Hi...
Please help me.... Tractor modell - JD 1020 (year 1975).... How I do start the PTO.... The clutch not responding....
If you want, I can send video...............................
The 1020 JD tractor (new) owner, from Europe...........
   / John Deere 1020 with poor hydraulic pressure #3
How long since hyd filter was changed & sump screen checked/cleaned??
   / John Deere 1020 with poor hydraulic pressure #4
Hi...
Does your tractor have a lever between the 2 gear shift levers?
Hi...
On my tractor it is on the left side under the front on the seat. It moves forward to engage. There was some changes between our model years. If not I can find out where it is.
   / John Deere 1020 with poor hydraulic pressure #7
The pto clutch may be stuck if your tractor has the dual stage type pto clutch. The photo shows the pto control lever you refereed to.
92" ARTICULATING 4 WAY SNOW PUSHER BLADE (A54756)
92" ARTICULATING 4...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A55788)
2006 International...
2018 Ford Transit 350HD Handicapped Van (A55788)
2018 Ford Transit...
2013 JOHN DEERE 470G LC EXCAVATOR (A52705)
2013 JOHN DEERE...
2017 Ford F-150 (A55788)
2017 Ford F-150...
