   / Your last generator Maintenance Run #181
Nice to have 240 on a gen, and having 2 is great for a long power outage, or general flexibility (helping a neighbour, giving tribute to Murphy :rolleyes:, etc....). It's a bonus getting a Yamaha engine in a generic, as their own branded ones are $$$$. Haven't set up my interlock yet for my larger gen.... what I have learned so far is that most of the interlock switching that is code legal in the USA is not code acceptable in Ontario, as we need to switch the Neutral as well. Rgds, D.
Homnestly, I haven't ask if the interlock kit is code legit or not.... My electrician rold em it should not be a problem and he would install it when I'll get it..... Haven't bought it yet, it is on my " to buy" list....... At least I have the generator and can run extension cord through the house if need be. I originally had 1 gen for the RV ( te champion) but got a heck of a deal on the EnerG, used, so I bought it for the house. And I realize that tere is oftentl one gen that is out aomewhere cause someone near by needed one.... But it is ok with me.
   / Your last generator Maintenance Run #182
Are you saying that because you have 3ph you seldom lose power on all 3 legs?
My garage has 3ph also and most of the local outages which include my house does not effect the flood lights I have on the garage.
90cummins
We have 3 phase grid but only single phase service to the house. In a power failure three phase grids get the first attention because they feed the single phase part of the grid. The lines may be higher above the ground??? but in our area the trees near them are clear cut from time to time which reduces outage risks.
On the old 12v DC-27 that is 12 years old and refuses to die I wonder if it was not from a test batch or something. When we bought the MH in 2007 the battery looked like crude on the inside and still does (gray soupy like) so I figured it was shot but now 7 years later it can set forever and keep a charge. While it is just a FLA it does act more like an AGM. It has to have some unique alloy metal.
It is a Dayton 7.5 kw.
I take the total KW hours and divide that into the total $$ out of my pocket and that is the figure that I pay for hydro. I worked out the cost of running a diesel genny compared to the cost of grid hydro and I am still ahead by $25./day to be on the grid.
The same goes for home heating oil. Dealer says $1.239 + hose tax so that equates to $1.40/L.
Thanks for gen info, and sharing those $ calculations. Still cheaper, but man, that is getting close in terms of grid cost !
Rgds, D.
A licensed electrician will know what your code is, and you may be different than Ontario (?). With the bad long outages this year, a few people have been thinking online here about back-ups to the back-ups... so long as they are maintained, multiple generators are great to have !
Rgds, D.
Now that you've posted that online Gale, watch out for the Men In Black pulling up at your garage ! :D
That battery probably doesn't officially exist, and there may be a bounty on it for Capture In The Wild !
Rgds, D.
   / Your last generator Maintenance Run #186
I seem to remember some batteries ha oil put in them - no kidding, it is true. However. everybody's idea of oil differed vastly. Last time I looked inside one of those, it had thick grey sludge - didn't didn't even check the voltage or amps! LOL
   / Your last generator Maintenance Run #187
Rgds, D.
Just hope they do not sue when they trip over stuff getting back to it. I was so glad we did not have to clean it out for a long generator run time this winter. :)
I hear ya Gale ! I built my own garage, but now could use another 1,000 sq ft in it ! :laughing:
One of my RoundTuit projects is building a proper generator shed..... that thought reminded me of a vid I sent to a buddy of mine recently.....
Lister D Generator & Charging set - YouTube
Anybody that likes machinery or woodworking should like that video, and the Lister fans can appreciate the work that went into balancing (I'd say he went beyond blueprinting :thumbsup:) that one.....
Perhaps I'm just a hopeless gearhead, but I find something meditative about the sound of a well-muffled Lister....
Rgds, D.
   / Your last generator Maintenance Run #189
Rgds, D.
Man after my own heart. :thumbsup:
   / Your last generator Maintenance Run #190
Just got in from fireing up portable JD genny. Hadn't run it in 2/3 months. Subaru powered unit. Just opened up fuel petcock /choke hit E-starter fired rite up. Will completely drain fuel from it this weekend. When I wanted to shut it down just closed fuel petcock and let run and die on its own then turned key to off position again. Can't comment much on this unit just used a little running power tools but have read reports from Rigid powered Subaru 404 cc and most were good.
If I had to say something negative about the Subaru motors is this particular model uses no oil filter.
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
2252 (A58376)
2252 (A58376)
2361 (A58376)
2361 (A58376)
VIDEO LINKS FOR ALL LOTS W/ VIDEOS (A59213)
VIDEO LINKS FOR...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
2019 KENWORTH T880 DAY CAB (A58214)
2019 KENWORTH T880...
