Bucket hooks
/ Bucket hooks #1
TexasBoy
Gold Member
Central Texas
Kubota M7060HDC12, L4600DT, Ford 4000
I had bookmarked the thread, but lost it.
What size bucket hooks did you guys end up putting on your loader bucket? Im gonna run and get some later today to weld on but thought Id ask what size you fellas ended up using.
Thanks in advance for any info.
/ Bucket hooks #2
5/16" bucket hooks are almost universal through about 50 horsepower tractors, above 50 horsepower some go to 3/8".
5/16" grab hooks hold 3/8", 5/16". 1/4" chain securely, 3/16" chain semi-securely.
5/16" chain is much lighter than 3/8" chain when you carry and drag it a few hours. Buy Grade 70 "Transport" chain or above. (Chain grades go to 100.)
I use Grade 70 - 5/16" myself. If I could find Grade 70 - 1/4" at a reasonable price I would try it. However, all 1/4" - Grade 70 I have seen is more expensive than 5/16" - Grade 70.
1/4" or 3/16" chain is useful when pulling out 1"-2" saplings with the FEL. Larger chain slips on small diameter saplings and tree roots.
Lowe's and Home Depot both sell Grade 70 - 5/16" X 20' chain, in a plastic bag, cheap, in their "towing" section. You can research current prices through their individual web sites. Have them cut the chain into 8' + 12' lengths in the store. You do not want to cut Grade 70 chain at home. Add two Grade 70 Slip Hooks and you will be ready to work.
You will use the 8' length far more than the 12' length.
/ Bucket hooks #3
I have always used 5/16 hooks, and 5/16 grade 70 chain.
/ Bucket hooks #4
I welded a bunch of 5/16 weld on grab hooks and some shackle mounts.
/ Bucket hooks #5
Yes, 5/16" seems to be the most common for sCUT and CUT sized machines.
/ Bucket hooks
Thank you guys very much.
/ Bucket hooks #7
Yep, 5/16 here too.. I couldn't find weld on hooks, had to butcher some regular ones.
Sean
/ Bucket hooks #10
In line with the loader arms. is best,
Yep, and my bucket needed reinforcement (in my opinion) on the top to avoid bending the top lip. I did it similar to Timster did in his pictures above.
/ Bucket hooks #11
I second James.
When moving tree trunks on the bucket, you will usually want one chain securing the load on each end.
When you pull out 2" - 3" trees with the roots, using bucket roll back, it is best to have the load lined up with the lift arms, where the bucket has the most support.
When dragging out moderate loads from the woods, to make them more accessible, frequently there is not space to push the entire bucket it. With in-line mounts, you can go in a little deeper with one corner of the bucket.
For heavy loads, don't use the bucket, use the rear center drawbar and a clevis mount grab hook. (Some sub-compacts and compact tractors require rear center mount drawbar to be purchased as an option.)
DON'T MOUNT HOOKS ON BUCKET ENDS. Torsion loads can lead to a "sprung" bucket.
/ Bucket hooks #12
I put a grab hook on each side and a slip hook in the middle. That way with a chain, I run through the slip and hook to a side grab hook where I can better reach it. If using a strap, I hook to the center slip hook. Works well for me.
/ Bucket hooks #13
I had mine put in the center that way I was sure to be fairly level and even when lifting. Put the strain on both arms equally and kept rig upright.
/ Bucket hooks #14
With the receiver hitch mounted in the center I have lots of options for lifting, towing etc.
/ Bucket hooks #15
I'm with Tom. I want my hooks out near the end of the bucket to get the most spread for lifting any object if needed. I also like the slip hook in the center for unusual lifts.
/ Bucket hooks #16
I welded one on each outer top lip of the bucket, which is not ideal. They should have been in line with the loader arms, but it's done now. I'm careful to balance the load.
I also put one on the center of the upper lip, for single chain lifts, and one on the bucket heel in the center too. For those times when the bucket is full of tools or material I don't want to dump, and for the most lifting capacity.
Sean
/ Bucket hooks #17
I bolted 1/2 inch hooks on the lower, outside edge. I use 3/8, grade 80 chain exclusively.View attachment 366252
----- and the day came when they fought like warrior-poets and won their FREEDOM ----0-
/ Bucket hooks #18
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366237"/>
You sure do. Very nice.
/ Bucket hooks
Put 5/16" on the ends for those instances you need to lift stuff up that requires a wider spread on chains, and 3/8" where the loader arms are, welded thsoe to the thick plate there. Although I will never be lifting anything heavy enough to cause it, all of them are fastened at a side/vertical plate to resist peeling up. Might do as others have and put a receiver in the middle eventually.
/ Bucket hooks #20
Nice work, looks factory
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
UNUSED RAYTREE AMBD72S-72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
UNUSED KJ 4PC WIRE MESH (A62131)
UNUSED KJ 4PC WIRE...
2025 Pabreak 74in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 74in...
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
