Attacking that power problem CT225
/ Attacking that power problem CT225 #141
I now have a 10000psi hyd pressure guage, but I have yet to test
my HST pressures. If someone else performs this test first, I hope he
reports here.
/ Attacking that power problem CT225 #142
I hate these threads that go hot and heavy and then just leave you hanging. I'm looking at a CT225 now, doing some research, and I'm wondering if this was ever resolved.
I resolved it....I got rid of the tractor.
/ Attacking that power problem CT225 #145
Well, this was an interesting read this morning. I just bought a CT225..:shocked:
Hopefully, these are exceptions to the norm, or "possibly" Bobcat corrected it in later year models.
Guess I'll be finding out soon enough. I've got a lot of hills on my property.
/ Attacking that power problem CT225 #146
I have never operated a CT225, but my Kioti DK35se (I think that would be a CT335) will spin the tires on solid ground in Low AND Med range. Of course it wont do it in High range. This is with my ballast barrel on the back, and with fluid loaded rear tires, so I am not hurting for traction either. Test your rig when you get it, push into a solid immovable object in Lo and Med and see what happens. I use my gravel pile.
/ Attacking that power problem CT225 #147
If I push the bucket into a large sand pile my CT225 will spin the tires with no problem.
/ Attacking that power problem CT225 #148
Will it do it in LO and MED ranges or just LO?
/ Attacking that power problem CT225 #149
It will do it in medium. However I don't have filled tires and the only ballast is a 60" box blade.
/ Attacking that power problem CT225 #151
Sounds normal to me.
It's normal for mine. :laughing:
It definitely doesn't like going up steep (20%) hills in high and not so keen on medium either. I usually change to low for them.
/ Attacking that power problem CT225 #152
When negotiating hills, do you press the HST pedal all of the way forward or just part way?
/ Attacking that power problem CT225 #153
No, if anything you let up on the pedal. I believe that that is why many HST owners-users do not like HST transmissions, they don't quite get how that they need to be used, and end up getting frustrated. :eek:
/ Attacking that power problem CT225 #154
MtnViewRanch,
Could you please explain how letting up on the pedal improves hill climbing ability?
/ Attacking that power problem CT225 #155
As you push down on pedal to increase speed is equal to shifting into a higher gear in gear transmission machine. Letting off the pedal to slower speed is equal to 'down shifting" to a lower speed that will increase torque through the drive system and require less horsepower to get same job done.
/ Attacking that power problem CT225 #156
SSdoxie,
Does the increase in torque happen in all three ranges?
/ Attacking that power problem CT225 #157
SSdoxie,
If you mean by letting up on the pedal do you have more power in each range, then yes that is how it works. ;)
/ Attacking that power problem CT225 #158
The HST pedal controls volume of oil flowing out of the pump to the HST motor which then turns the gear box & differentials (determines speed). The pressure required to move depends on the load, resistance to move. Flow @ pressure determines the horse power required from the engine. When trying to do a specific job and engine starts to labor, reducing the flow (let up pedal) reduces the HP requirement to engine.
Quick example: I don't know what full pump flow capacity is but I'll use 15 GPM as example.
At full pedal 15 GPM, if load resistance requires 3000 PSI = 26 HP from engine to move. If you let up on the pedal to flow @ 13 GPM at 3000 PSI load= engine only needs to put out 22 HP to move the tractor.
/ Attacking that power problem CT225 #159
My brain is wired poorly for topics like this.
I'm sitting here really trying to grasp this concept.
Don't I need MORE power to get up the hill? If I had a 40hp or 50hp tractor would I still need to let-up on the pedal?
/ Attacking that power problem CT225 #160
At a certain point of weight to horsepower you do overcome it. But other wise to down shift a hydro you let up on the petal.
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2023 Case TV620B (A64119)
2023 Case TV620B...
2005 John Deere 7420 (A60462)
2005 John Deere...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
McCormick X6.55 (A64126)
McCormick X6.55...
APPROX(15) DIAMOND PATTERN PLASTIC PROTECTION MATS (A64281)
APPROX(15) DIAMOND...
