TnT from b7500 to b7800
   / TnT from b7500 to b7800 #1
Stokes760
Member
Ramona Ca
kubota b7800 cat 939c
Some one local is selling a TnT gearmore kit rams hoses 2 spool valve for $500
Only concerned it wont be enough for the 7800 senice it was for b 7500
should I buy it anyways?
   / TnT from b7500 to b7800 #2
300 lb lift difference, both Cat I... I would venture a guess it'd be perfectly fine on the 7800 and suitable for much larger units as well.
So I picked up the tnt kit ended up being a bare-co with out hoses. Just two issues when I bought the 7800 it had rear remotes installed off a gearmore kit. Wondering if I should use whats there or use everything from bare co. Also the tilt cylinder ports are faced towards tractor if mounted on right side. Can mount on right and have ports face tractor or mount left side and have ports face out. What do you guys think.
Double post.....
   / TnT from b7500 to b7800 #6
Mount the side link on the left side and route the hoses accordingly. As far as the valves, just use what you have in place. ;)
Thanks mtn view was hoping that you would chime in. I do notice that I look over my right shoulder when working behind. Any advantages of seeing the ram when workijg tnt
   / TnT from b7500 to b7800 #8
You can still look over your right side. You can still have it move up or down on the right side however you want to be moving the lever. No real need to see the hydraulic, just the implement. I have actually had a few customers install the side links on the left side just because the hoses routed better on their tractor from that side. Let me know if the local hose shop is to much $$$. I can get you your 4 hoses with the male QD ends and 2 sets of flow restrictors for $129.30. I can mail them to you for $12 or you can just come down to Lakeside. ;)
I can make my own hoses got a crimper for the offroad cars I build standard automotive stuff didnt hold up. Im interested in those flow restrictiors. I know 1/4 line will slow down to about 3 gpm is that still to fast.
   / TnT from b7500 to b7800 #10
The flow restrictors are .030 if that gives you an idea. ;)
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2017 Ford F-250 Enclosed Service Truck (A53422)
2017 Ford F-250...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2018 JLG G5-18A (A50123)
2018 JLG G5-18A...
