cross over relief for snow plow
   / cross over relief for snow plow #11
Are you saying that you dump from one cyl to another cyl.
A single SA cyl only has one side. The other side is air.
Yes JJ, that is how those valves work. In effect they are more or less specific to snow plow type operations.
It would be like having 2 SA cyls connected together with one single hose, the movement of one will be replicated by the other and in effect can replace throttle cables (bowden).
PRV's usually have 3 ports, in/out and 3rd return to reservoir. In case of crossover rather than to tank it dumps to other s/a pressure line hence only 4 ports.
   / cross over relief for snow plow #12
grsthegreat ,
You mean that you only have one cyl to push and let the ground force retract/close the cyl.
A relief valve can be set up on just about hyd cyl to protect that cyl, when the valve is in neutral.
No you do not need a double relief for a single action cyl.
Some valves have work port relief.
My BH bucket spool has double work port reliefs.
JJ, no i have a single double acting valve to run the snow blade. It powers to retract and powers to extend. I see that some plows have twin cylinders that oppose each other...and im not sure if there single or double acting.
i was wondering if they make a cushion valve for a single double acting system
thanks
   / cross over relief for snow plow #13
I have always wondered, but how well do they work on a single DA cylinder due to the difference in volumes of fluid between the rod side and the base side? I just assumed they wouldnt work well at all??
They work a whole lot better than not having one at all. Designing a plow with one double acting cylinder is a cost cutting deal. Dual single acting is a better design and used by most mainstream plow builders.
   / cross over relief for snow plow #14
you definitely need a cross over on the plow cylinders, a short curb and your looking for hoses.. cylinders ... blades ... loader arms... etc.. i use these units.. CRV08-20 Hydraulic Pressure Control Valve Jim
getting advice for snow plows from Florida is like getting advice for sunscreen from some one in Alaska!!! LOL
   / cross over relief for snow plow #15
thanks
Here's a picture of my old HLA plow showing a cushion valve on an angled single cylinder. (It worked great and kept the blade closer to the tractor)
It looks like the same valve on my new plow, which is a dual cylinder. (second photo)
   / cross over relief for snow plow #16
ah... ok now i see whats involved. i can add something like that easily. And i do see how that would be cheap insurance for my expensive plow and loader.
   / cross over relief for snow plow #18
Come to think of it, my backhoe has a cushion valve similar to that second plow with 2 DA cylinders. To protect the lines when you have a heavy scoop and are swinging and go to stop. Without the valve, all of that energy has to be absorbed by the lines when the valve slams closed. The cushion protects that.
Not saying it don't help, but certainly works better with two cylinders as opposed to a single DA. Cause fluid volumes are equal with 2 cylinders.
   / cross over relief for snow plow #19
You don't think that anybody that made their living plowing snow ever retired to Florida? :rolleyes:
2013 FREIGHTLINER EXTENDED CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
(4) ROLLS OF MISC CARPET (A54757)
(4) ROLLS OF MISC...
PumpJack Brand Pump Jack (A55218)
PumpJack Brand...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
New Kivel 3500 lb. Skidloader Forks (A50775)
New Kivel 3500 lb...
