nybirdman
Super Member
I think I need to put a cross over relief on my FEL mounted snow plow.Anyone have a parts number and pipeing diagram.It is an old Curtis truck plow ,fairly new cylinders&hoses.
Are you saying that you dump from one cyl to another cyl.
A single SA cyl only has one side. The other side is air.
grsthegreat ,
You mean that you only have one cyl to push and let the ground force retract/close the cyl.
A relief valve can be set up on just about hyd cyl to protect that cyl, when the valve is in neutral.
No you do not need a double relief for a single action cyl.
Some valves have work port relief.
My BH bucket spool has double work port reliefs.
I have always wondered, but how well do they work on a single DA cylinder due to the difference in volumes of fluid between the rod side and the base side? I just assumed they wouldnt work well at all??
i was wondering if they make a cushion valve for a single double acting system
thanks
Here's a picture of my old HLA plow showing a cushion valve on an angled single cylinder. (It worked great and kept the blade closer to the tractor)
It looks like the same valve on my new plow, which is a dual cylinder. (second photo)
You don't think that anybody that made their living plowing snow ever retired to Florida?you definitely need a cross over on the plow cylinders, a short curb and your looking for hoses.. cylinders ... blades ... loader arms... etc.. i use these units.. CRV08-20 Hydraulic Pressure Control Valve Jim
getting advice for snow plows from Florida is like getting advice for sunscreen from some one in Alaska!!! LOL
I had to look at that setup a while to trace out what was going on with it. That must be a very snappy swing if any real volume comes in from the main pump.
