Modified air intake, air filter stays cleaner..
   / Modified air intake, air filter stays cleaner..
Very nice work, pics, paint, details, cup-holder ...
I hope we'll see more from this clever creator. :thumbsup:
I want to say thank you as I think that is a very big compliment....
   / Modified air intake, air filter stays cleaner.. #12
The way it is designed it will not let water into the intake....[/QUOTE said:
It's just for looks! :)
   / Modified air intake, air filter stays cleaner.. #13
What an excellent job on a workhorse tractor. A pre-cleaner is a great idea in general and I have often thought of adding one to my MX5100 that is swamped in dust at times. For those of us less talented there are universal pre-cleaners that are sold at some ag places but the instillation is still up to the user.
Good job here.
   / Modified air intake, air filter stays cleaner.. #14
Apparently, you don't remove the loader much? Looks nice.
Aaron Z
   / Modified air intake, air filter stays cleaner.. #15
Nice. My JD has the same stock setup. I've been considering a similar change. Will reroute exhaust at same time if I ever get properly motivated.
Brock...
Aaron Z
Never, but it would not be a problem if I wanted to, just one screw and it comes off
   / Modified air intake, air filter stays cleaner.. #17
Looks good.
What kind of seal is there between the factory air box and your extension?
Looks good.
No seal needed the pipe I used is a very tight fit onto the air box fitting, even if it did not fit tight it is before the air filter...
   / Modified air intake, air filter stays cleaner.. #20
It looks like it might be the same box used on the RTV. I really need to do something similar (to my RTV) to keep from buying so many dang outer filters.
I understand it is pre-filter.
What type of pipe is that?
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
Portable Restroom (A54865)
Portable Restroom...
PORTABLE HAY FEEDER TRAILER (A52708)
PORTABLE HAY...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
