Modified air intake, air filter stays cleaner..
   / Modified air intake, air filter stays cleaner..
Very nice work, pics, paint, details, cup-holder ...
I hope we'll see more from this clever creator. :thumbsup:
I want to say thank you as I think that is a very big compliment....
   / Modified air intake, air filter stays cleaner.. #12
The way it is designed it will not let water into the intake....[/QUOTE said:
It's just for looks! :)
   / Modified air intake, air filter stays cleaner.. #13
What an excellent job on a workhorse tractor. A pre-cleaner is a great idea in general and I have often thought of adding one to my MX5100 that is swamped in dust at times. For those of us less talented there are universal pre-cleaners that are sold at some ag places but the instillation is still up to the user.
Good job here.
   / Modified air intake, air filter stays cleaner.. #14
Apparently, you don't remove the loader much? Looks nice.
Aaron Z
   / Modified air intake, air filter stays cleaner.. #15
Nice. My JD has the same stock setup. I've been considering a similar change. Will reroute exhaust at same time if I ever get properly motivated.
Brock...
Aaron Z
Never, but it would not be a problem if I wanted to, just one screw and it comes off
   / Modified air intake, air filter stays cleaner.. #17
Looks good.
What kind of seal is there between the factory air box and your extension?
Looks good.
No seal needed the pipe I used is a very tight fit onto the air box fitting, even if it did not fit tight it is before the air filter...
   / Modified air intake, air filter stays cleaner.. #20
It looks like it might be the same box used on the RTV. I really need to do something similar (to my RTV) to keep from buying so many dang outer filters.
I understand it is pre-filter.
What type of pipe is that?
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
Portable Restroom (A54865)
Portable Restroom...
2013 Ford E-Series Cargo Van, VIN: 1FTNE1EW5DDA01380, Gas Engine, Automatic Transmission, GVWR: (A59076)
2013 Ford E-Series...
2016 GENIE S-65 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE S-65...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
John Deere 7410 (A53317)
John Deere 7410...
