First Aid Kits and Supplies
/ First Aid Kits and Supplies #1
3930dave
Super Star Member
Canada
Ford 3930
I'm updating my 1'st Aid Kits, and the threads I could find on here were either pretty old, or a Trauma level beyond my capability.
I'm looking for input on favourite Kit supplies, and any particular First Aid product Brands that you prefer.
Specifically:
- Cases that stand up well to moderate transportation use
- Bulk Bandage material - looking for USA or Canadian manufactured product
- small band-aid recommendations. I used to be an Elastoplast fan years ago, not so much any more. About the only one I've found that stands up to water well is a plastic Band-Aid version - I'm still looking for a fabric one with an effective adhesive. (I know band-aids aren't supposed to stay on indefinitely ;) , I'm just tired of them falling off the first time I wash my hands).
- antibacterial products with long shelf lives, and robust containers
- any other product suggestions or First Aid tips are welcome
Rgds, D.
/ First Aid Kits and Supplies #3
You can still get Elastoplast strip bandaids, I think. You really gotta hunt for them. I have two bottles of Detol, one in the human kit and one in the animal kit. A Quart of Absorbine horse liniment, (for the animals) rubbing alcohol, ammonia smelling salts, triangular bandage, assorted splints.
/ First Aid Kits and Supplies #4
don't forget 2 crucial additions : small bottle of crazy glue and roll of surgical tape ...
crazy glue to glue flaps for skin back in place and stop gross bleeding
surgical tape to hold it all together for those big cuts .....
/ First Aid Kits and Supplies #5
Black electrical tape works for a pressure bandage after the gauze goes on. I like 4x4 telfa pads, too. They don't stick to the wound. Don't forget a pair of scissors and the forceps. Also, peroxide.
Thanks All for the suggestions, it is appreciated.
I like Hydrogen Peroxide for general use on small cuts. Seems to do the trick for us, w/o the YOWWCCCHHHH factor you get into with alcohol based product. The one point I've come across lately was that peroxide can be a bit too aggressive in terms of oxidizing action - I need to research that issue a bit more, esp. re. larger wounds.
I've heard good things about Crazy Glue for skin fixes, but never used it myself. If a tube of Crazy Glue is NOT opened, how long a shelf life do people get ? I don't use it in my shop that often, so when I go back to an open tube, it is usually solid by then.
I've got some 3M surgical tape I like, but then again I can't recall being ever let down by a 3M product. Elec. tape is a good suggestion - strong, relatively easy to remove, and I always have some around anyway.
Elastoplast I can find, but the basic consumer level stuff I've found lately isn't what it used to be in terms of fabric thickness and adhesive qualities. Last I looked, the Elastoplast small bandaids we get here are made in Spain. Doing foundation work on my garage, I resorted to winding masking tape around dings on my fingers - worked at least as well as any bandaids I could find at the time.
Brin - I recently had direct experience with surgical staples - I have to say, from a Mech Eng standpoint, I was impressed - apparently they have been around for quite a while too. I'm going to update my kits in 2 stages - the items you touch on will go into a later Back Country/SHTF level kit. I always carry a reasonably sharp knife, that after a dose of peroxide can stand-in for an emergency basic scalpel. Same goes for the pliers on my Leatherman - not as sanitary as sealed products, but will work better than fingers if needed.
Rgds, D.
/ First Aid Kits and Supplies #8
crazy glue will last forever unless exposed to air ( opened tube) or direct sunlight ( UV) or water ( solvent)
surgical tape will stick to bare skin and is flexible but strong. ( leaning more towards the really big OOOPS! what have I done?, cuts here...) as in taping up a good chunk of limb.
/ First Aid Kits and Supplies #9
I found elastic vet wrap works great to wrap almost any booboo. And it sticks to itself even when wet.
Sealed tubes of Crazy Glue for the kit it is then ! I've seen it applied to a cut, then spread evenly using a layer of saran wrap briefly - just to distribute it over the cut area - saran wrap then removed. So I'll add some wrap too.
I've been pleased with the 3M surgical tape I have, so will buy more - hoping I don't have to use much of it though !
Rgds, D.
Now, that's an interesting point. I've never had occasion to see vet wrap used.... but it stands to reason that it would have to be a pretty bulletproof solution - few animals with mobility will respect the bandage much - though the wife might say the same for me ! :D
Does someplace like Petsmart carry that, or is it Vet/industrial distributors only that do ?
Rgds, D.
/ First Aid Kits and Supplies #12
Rgds, D.
I get vet wrap at the local TSC if in a hurry but keep a supply ordered from a vet supply for my horses, goats and me.
/ First Aid Kits and Supplies #13
Peroxide is a no-no in open wounds. It's good for cleaning around a wound when you're doing dressing changes, but that's it. It will damage the cells and cause all kinds of problems if you then close up the wound and bandage it. Clean water only for rinsing debris out.
TSC, that makes sense, thanks.
Rgds, D.
Thanks Tim. I've never used it on a large wound, and don't plan to now that I know better.
What I'm after is a product to disinfect something like a minor cut from rusty metal, or a small bite from an unknown animal - not a major wound opening, but you have motivation to quickly disinfect it if you can. Water alone probably won't deal with the bugs like that, and while I can grit my teeth and use alcohol on my own cuts, the wife or other people won't thank me for that move when they have the cuts themselves.
IF peroxide is used, I have to learn more about how long it has to be flushed with water immediately after.
Rgds, D.
/ First Aid Kits and Supplies #17
Rgds, D.
Well, anything that's going to require stitches should just be rinsed out with clear water, and left open. Pack the wound with dressing to control the bleeding and take them to the ER. Applying anything else will just cause complications. Now if we are talking days of travel time to get out of the bush, then the game changes a little.
I have to take wilderness first aid every two years as part of my job. It's a three day course. Not saying I'm an expert or anything....
The worst bites you can get btw are Humans and Cats in terms of infection.
/ First Aid Kits and Supplies #18
Dave, you mentioned needing a case that would stand up to abuse. I would recommend getting one of the smaller pelican cases. When I started back mountain biking I put together my own FA kit because I wasn't really happy with the options immediately available to me and used one of pelican's micro-cases. They come in a couple handy sizes so you can pick one to suit your needs.
One of the neat things I found at TSC aside from the vetwrap already mentioned is that they have a large supply of needles for animal immunizations. I picked up a small box of 18ga needles and keep one in my first aid kit and couple around the house. They are awesome for teasing out splinters, and I've found come in handy for a multitude of other random tasks.
I noticed a couple of people mentioned keeping super glue for first aid. Just my two cents but if you are going to go that route go ahead and spend the 17.00 to 20.00 and order some vetbond online. Superglue, vetbond and dermabond generally speaking are a related family of cyanoacrylates. The variants found in over the counter super glues tend to be comprised of cyanoacrylates that are tissue irritants, present some toxicity issues that can impact wound healing, and can produce an uncomfortable amount of heat curing in a wet environment.
I'm not saying that regular superglue can't be used in a first aid situation, nor am I saying it hasn't been used without ill effects. Just wanted to throw out a slightly healthier option.
/ First Aid Kits and Supplies #19
If you looking for kits look at Chinook medical They have many different kits from burn, trauma, puncture etc.
I have a few of theirs and I also bought a tourniquet and two different size neck immobilizers. My daughter who is 6 knows how to put the neck brace on me and where we keep the kits so if I ask for it she will get it for me. I worry about being so far away from medical help that every minuet counts.
I also tried to think about what would most likely happen, burn (yes fuel spill etc), puncture sure fall on something or archery season, trauma same, neck easy to happen.
Thanks for the link. I bumped that old Stiptic Powder thread, and got more good feedback there.... so I'll buy a vial of Stiptic powder, and see what pricing I can track down for Quick Clot - that format would be a fast compress for a large wound, the Stiptic sounds like the product to start with for a small leaky cut.
Rgds, D.
