JD 5205 Has Blinking Hour Meter Display
/ JD 5205 Has Blinking Hour Meter Display #1
Zebulon101
John Deere 5205
I have a John Deere 5205 where everything in the small hour meter display (which also has miscellaneous symbols in it) is blinking all 8's. I haven't noticed any operational differences in the way it runs or operates (other than the fact that I have no idea how many hours I have on the tractor).
Anyone have ideas on how to correct this problem?
Thanks!
/ JD 5205 Has Blinking Hour Meter Display #2
The electronics in the "gauge" are probably shorted out from water etc.
My guess would be, you need a new gauge.
/ JD 5205 Has Blinking Hour Meter Display #3
Thanks!
Hi,
I have a 5205 that just started blinking. Did you figure out issue?
/ JD 5205 Has Blinking Hour Meter Display #4
Thanks!
Did u findout the issue
/ JD 5205 Has Blinking Hour Meter Display #5
I also have a 5205 with about 1775 hours on it that just started blinking hour meter display with same symptoms. Kept in a shed so I don't believe its a moisture problem. A new display is $478. Hoping someone knows of a fix.
/ JD 5205 Has Blinking Hour Meter Display #6
Thanks!
I see this is an old post. Did you find a solution for this?
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2022 Ram ProMaster 2500 Cargo Van (A61573)
2022 Ram ProMaster...
2018 Ford Escape SUV (A61574)
2018 Ford Escape...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2023 Stearling Trailer (A60352)
2023 Stearling...
