CNC Plasma Table software
/ CNC Plasma Table software #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I'm buying a CNC plasma table the computer has the following software ...
Mach3 -
SheetCam -
Lazycam -
DesignSight -
Inkscape -
Anyone using these or 1 or any combination? I've been reviewing the software on line and for a completely new to the plasma world its all like reading "Greek" !!!
Any suggestions, videos, advise, experiences will be very appreciated!!!
/ CNC Plasma Table software #2
I have friends in the CNC business. Never heard mention of any of these.
They all speak "Solid Works"
I would love to get into this, but don't figure I would ever use it enough to remember it for when it was needed.
How big a table did you get? How much dough? Which cutter?
Arcsheild would probably be able to answer all your questions.
I bought a 5x10 table .. I have a longevity 42i plasma to hook to it .. I've had for the last 3yrs the local machine shop cut my hay grapple hooks .. Average 25 sets a yr at $550 each set so I thought it was time to get setup to cut my own.
It's a scary step .. I've no experience with the software, the table .. I'm concerned I'll get it all set up and just won't be able to use it!!!
The local shop uses a couple of the software programs ... But although I can lean on him some .. I'm hoping to get info and all the help I can get .. Actually maybe somebody is using the same!!
/ CNC Plasma Table software #4
I would get as much thin scrap as I could to practice on.
There will be a learning curve, no doubt about that.
I just learned that my friend has left the shop through which I got all my stuff done, and he was a genius at drawing! So what am I gonna do now? They had two Lasers and a Plasma that would do well over an inch!
/ CNC Plasma Table software #5
I am mostly ignorant about cnc/plasma machines...but I do know a bit about software/computer controlled systems...
...I would bet that your machine will recognize a common/typical file type / extension...i.e., ".cnc" etc...
I would guess that you can use about any CAD software and as long as the extension is compatible it should work for design programs...
Good luck with your new system...will look forward to seeing pictures of some of your projects...
/ CNC Plasma Table software #6
sorry, my table uses different software.
Basically the steps are the same. Make the drawing - i use coraldraw or Autocad depending on item.....coraldraw does just fine for most everything.
then you have to convert the drawing (export) as a windows bitmap
then trace this bitmap... i use a program called vextractor cause its fast and easy to use. the tracing is saved as a .DFX extension that will be recognized by plasma software.
but it doesn't stop there. Most people (like me) want to save as much steel on the table so use a nesting software. This allows the computer to flip and flop all cuts around to maximize the material that you can cut from a sheet of steel.
I use a program called Enroute3 with nesting. This software also sets your cut starts , depth of cuts, offset to allow for torch cutting width, etc. All these things happen in a few seconds and is controlled by the parameters you set up.
I had to start by cutting all different thicknesses of steel and measuring the kerf width (the thickness of the torch cut) and installing these figures in the software. This allows the software to autocorrect for cut thicknesses while cutting. without this step you finished pieces wont measure up correctly.
On my system, once this is set, you never have to worry about it again. You just tell the plasma computer the thickness of steel your cutting, all done.
Oh, and less i forget. You also have to figure out all the settings. Air, cutting amps, and distance of cutting head from surface...also pierce height.
This step took the most time in the learning curve. My dynatorch system had a hand cutting option that runs off of a hand held joystick, and by cutting by hand, you can continually hand adjust speeds, torch height,amps, etc till the cuts look good. then record these settings for future use. Once learned for each steel thickness you use, its there in memory of computer for future use.
Believe me, youll be burning up steel scraps and consumables till you get the settings, then it will be smooth sailing after that.
One other thing that has saved me money over the years was the addition of a torch height sensing device that dynatorch created. With this item, the machine uses a laser to find steel surface so the computer knows exactly where the steel is to begin the pierce.... without the cutting head touching the steel. I used to waste more heads when the unit used to touch the steel plate.
I am mostly ignorant about cnc/plasma machines...but I do know a bit about software/computer controlled systems... ...I would bet that your machine will recognize a common/typical file type / extension...i.e., ".cnc" etc... I would guess that you can use about any CAD software and as long as the extension is compatible it should work for design programs... Good luck with your new system...will look forward to seeing pictures of some of your projects...
Thanks .. Your pm box may get full !!!
sorry, my table uses different software. Basically the steps are the same. Make the drawing - i use coraldraw or Autocad depending on item.....coraldraw does just fine for most everything. then you have to convert the drawing (export) as a windows bitmap then trace this bitmap... i use a program called vextractor cause its fast and easy to use. the tracing is saved as a .DFX extension that will be recognized by plasma software. but it doesn't stop there. Most people (like me) want to save as much steel on the table so use a nesting software. This allows the computer to flip and flop all cuts around to maximize the material that you can cut from a sheet of steel. I use a program called Enroute3 with nesting. This software also sets your cut starts , depth of cuts, offset to allow for torch cutting width, etc. All these things happen in a few seconds and is controlled by the parameters you set up. I had to start by cutting all different thicknesses of steel and measuring the kerf width (the thickness of the torch cut) and installing these figures in the software. This allows the software to autocorrect for cut thicknesses while cutting. without this step you finished pieces wont measure up correctly. On my system, once this is set, you never have to worry about it again. You just tell the plasma computer the thickness of steel your cutting, all done. Oh, and less i forget. You also have to figure out all the settings. Air, cutting amps, and distance of cutting head from surface...also pierce height. This step took the most time in the learning curve. My dynatorch system had a hand cutting option that runs off of a hand held joystick, and by cutting by hand, you can continually hand adjust speeds, torch height,amps, etc till the cuts look good. then record these settings for future use. Once learned for each steel thickness you use, its there in memory of computer for future use. Believe me, youll be burning up steel scraps and consumables till you get the settings, then it will be smooth sailing after that. One other thing that has saved me money over the years was the addition of a torch height sensing device that dynatorch created. With this item, the machine uses a laser to find steel surface so the computer knows exactly where the steel is to begin the pierce.... without the cutting head touching the steel. I used to waste more heads when the unit used to touch the steel plate.
THANK YOU!!! Good advice .. Sounds like practice, practice and practice .. Then practice till you get it .. To start with I need my grapple hooks so I can cut them out .. 22 per set and average 25 sets per yr .. If I accomplish nothing more than that I'll be happy!!
/ CNC Plasma Table software #10
once you get use to using the software, you can go from making the drawing to cutting the steel in less than 15 minutes.
I just cut out all the pieces for a guy that wanted to make his own woodburning fireplace for a sheep herders wagon. This had quite a few cuts, so took about 30 minutes to complete the initial artwork to scale off his drawing. Then about 2 minutes co trace and make DFX files, and about 3 minutes to nest and set cutting parameters.
The longest time was set warming up my shop so i could work. it was 8F outside. You have to warm the shop up enough so the stepper motors on the plasma table work right. too cold and they dont respond to commands.
I use a warm-up program that the guys at dynatorch created that slowly ramps up the speed of the table white tracing a set program...WITHOUT actually cutting anything. Takes about 15 minutes to do, but in the winter it HAS to be done
in summer, just go aheas and cut
/ CNC Plasma Table software #11
considering what I know (about CNC) and what I've read here...me thinks that 'grsthegreat' will be a much better source of viable information for getting your system set up...
I mostly write command and control software using standard system (shell) language...I am not familiar with CAD etc. design programs...
again good luck...
/ CNC Plasma Table software #12
what thickness steel
/ CNC Plasma Table software #13
ok, MACH3 is the software that actually controls your plasma cutting head. It uses the cutting codes generated from lazycam (mine uses enroute3 to create cutting codes)
/ CNC Plasma Table software #15
Inkscape appears to be a basic drawing program and creates the vector (trace) images youll need and Designsight appears to be a free CAD emulating program
/ CNC Plasma Table software #16
i went ahead and downloaded draftsite and inkscape... ill play around with them. im always looking for new cad software. i wasn't familiar with these. and heck..there free
/ CNC Plasma Table software #17
If you need any help with you dxf files just shoot me an message. That's what I've done for the past 10 years for GE. I run a hypertherm 400xd. Do you know what kind of file extention your controller uses for nesting. For example. .eia or .cnc
Let me know what you think of them
2005 John Deere 225CLE Hydraulic Excavator (A66734)
2005 John Deere...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
17in. Bucket w/ Teeth Excavator Attachment (A68183)
17in. Bucket w/...
2013 ELECTRO-STEAM INDUSTRIAL PRESSURE WASHER (A65054)
2013 ELECTRO-STEAM...
