John deere 1010 ru 1964 radiator removal has power steering
   / John deere 1010 ru 1964 radiator removal has power steering #1
deltaboy400
Lebanon tn
John deere1010 1964ru
Need to remove radiator has power steering unit thru top of rad. Not sure about where to start with p/s unit removal help please thanks.
   / John deere 1010 ru 1964 radiator removal has power steering #2
In the same boat, need to remove the steering shaft (armstrong steering) in order to remove radiator. Did you have any luck? If no replies, I'll start the job using good old yankee ingenuity. I hope I don't break to much.
   / John deere 1010 ru 1964 radiator removal has power steering #3
Isn't there a splined coupling on the shaft? Should be able to remove that, .... or not?
A pic of your dilemma would help point out a next step, I'd think.
Here is jdparts.com schematic.. shows two splined couplings.. with cap screw in each.
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2015 Ford Explorer (A50324)
2015 Ford Explorer...
2012 International Day Cab Truck Tractor (A50323)
2012 International...
2004 DYNAPAC CA152PD PADFOOT ROLLER (A51242)
2004 DYNAPAC...
John Deere 2010 Loader Tractor (A50514)
John Deere 2010...
