MT2850 wON'T MOVE
/ MT2850 wON'T MOVE #1
roadkingryder
mena,ar
285 mitsubshi
2850 will not move in forward or reverse. Any suggestions?
/ MT2850 wON'T MOVE #2
I had a John Deere 790 do that to me once,looked for a long time before I found the 4 wheel drive lever was accidently kicked half way between 2 and 4 wheel drive . Just one thing to check.
/ MT2850 wON'T MOVE
I tried that, no bueno. Filled the hydraulic oils and still won't move. Think it might be the clutch?
/ MT2850 wON'T MOVE #6
I'm assuming 19 days later you figger'd something out.
mine did that once...after I had the trans cover off and back on...the knuckle head working on it (me) got things out of wack, and somehow stuck her in two gears at once. popped the cover again (not fun with blue rtv almost cured), and loosened things back up. presto-chang-o she goes!
also...the clutch storage arm isn't flipped around and holding the clutch pedal down is it?
(4) RUBBER TIRE LOADER TIRES (A62613)
(4) RUBBER TIRE...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
2018 Dodge 5500 Bucket Truck 4WD (A63689)
2018 Dodge 5500...
Bandit 250XP Wood Chipper (A63689)
Bandit 250XP Wood...
