airfilter number for gas 4010 trans 2009 and
   / airfilter number for gas 4010 trans 2009 and #1
Michelle K linnane
Gold Member
Esperance NY
JD 4103
I can not find the air filter number for my 4010 trans Gas 2009. Can someone tell me a napa or advanced auto part number
   / airfilter number for gas 4010 trans 2009 and #2
They aren't that expensive from the dealer, and you can get aftermarket versions from different M/C, UTV, ATV vendors.
I'd need the exact model number of your Mule to be sure, but most of the gas Mules use the same filters. If so, your air filter should be: 11013-1290
partzilla.com has this listed for less than $20. You can also get it off of Amazon.
The last one I got for my 610 Mule was about $40 from the dealer. Unless you're doing a LOT of riding, the filter should be good for the number of hours listed in your maintenance schedule. And you can usually blow them out with air to get more life out of them.
Don't forget about the other air filter. You also have one for the CVT breather (the transmission). It will run about $17 at partzilla. It should be: 11013-1263
Again, the best way to make sure you're getting the correct parts is to get your exact model number off the machine. It will look like: KAF620S9F (it may be different)
Now, with all that being said. Looking at the FRAM filter catalog, if we search on the Kawasaki part number, we come up with listing for a FRAM CA9248 which is a cross-reference for a NAPA 6449. So the 6449 should be a match for the OEM filter :thumbsup:.
Here are all the cross-reference numbers:
AC-DELCO A2181C
BALDWIN PA4632
BALDWIN RS3715
BIG A 94449
CARQUEST 88449
CASE 6191362M1
CHAMP AF2308
DONALDSON FPG042544
DONALDSON P812440
DONALDSON P822686
FLEETGUARD AF25538
FLEETGUARD AF25550
FLEETGUARD AF25745
FLEETGUARD AH19082
HASTINGS AF2308
HASTINGS PA4632
HASTINGS RS3715
JOHN DEERE M113621
KAWASAKI 11013-1290
KRALINATOR LA1646
KUBOTA 6A100-82630
KUBOTA 6A10082632
KUBOTA 6A100-82632
KUBOTA 6C060-99410
KUBOTA K1211-82320
LUBER-FINER LAF8388
NAPA 6449
PUROLATOR A35270
TORO 932195
VOLVO 6050126
WIX 46449
YANMAR 119655-12560
If you go with something other than Kawasaki, be sure to take the old filter with you so you can compare it against the new one.
Good luck,
NV
DEUTZ MARATHON...
2022 CAT PR121 84" Box Rake (A53317)
2022 CAT PR121 84"...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
23169 (A50324)
23169 (A50324)
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
